<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_xml" compatibility="5.3.013" expanded="true" height="60" name="Read XML" width="90" x="45" y="30"> <parameter key="file" value="C:\home\ebrahimi\Anomaly\seg10Train.xml"/> <parameter key="xpath_for_examples" value="conversations/conversation"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="@id"/> <parameter key="xpath_for_attribute" value="message/text"/> <parameter key="xpath_for_attribute" value="message/author"/> </enumeration> <list key="namespaces"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.3.002" expanded="true" height="60" name="Data to Documents" width="90" x="179" y="30"> <parameter key="select_attributes_and_weights" value="true"/> <list key="specify_weights"> <parameter key="tex" value="1.0"/> </list> </operator> <operator activated="true" class="text:filter_documents_by_content" compatibility="5.3.002" expanded="true" height="76" name="Filter Documents (by Content)" width="90" x="313" y="30"> <parameter key="condition" value="contains match"/> <parameter key="regular_expression" value="</text><text>"/> </operator> <operator activated="true" class="loop_collection" compatibility="5.3.013" expanded="true" height="76" name="Loop Collection" width="90" x="447" y="30"> <process expanded="true"> <operator activated="true" class="text:write_document" compatibility="5.3.002" expanded="true" height="76" name="Write Document" width="90" x="112" y="30"/> <connect from_port="single" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Read XML" from_port="output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Filter Documents (by Content)" to_port="documents 1"/> <connect from_op="Filter Documents (by Content)" from_port="documents" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_xml" compatibility="6.0.003" expanded="true" height="60" name="Read XML" width="90" x="45" y="30"> <parameter key="file" value="C:\home\ebrahimi\Anomaly\seg10Train.xml"/> <parameter key="xpath_for_examples" value="conversations/conversation"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="@id"/> <parameter key="xpath_for_attribute" value="message/text"/> <parameter key="xpath_for_attribute" value="message/author"/> </enumeration> <list key="namespaces"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="6.4.001" expanded="true" height="60" name="Data to Documents" width="90" x="179" y="30"> <parameter key="select_attributes_and_weights" value="true"/> <list key="specify_weights"> <parameter key="tex" value="1.0"/> </list> </operator> <operator activated="true" class="text:filter_documents_by_content" compatibility="6.4.001" expanded="true" height="76" name="Filter Documents (by Content)" width="90" x="313" y="30"> <parameter key="condition" value="contains match"/> <parameter key="regular_expression" value="</text><text>"/> </operator> <operator activated="true" class="loop_collection" compatibility="6.4.000" expanded="true" height="76" name="Loop Collection" width="90" x="447" y="30"> <parameter key="set_iteration_macro" value="true"/> <process expanded="true"> <operator activated="true" class="text:write_document" compatibility="6.4.001" expanded="true" height="76" name="Write Document" width="90" x="179" y="30"> <parameter key="file" value="C:\home\ebrahimi\Anomaly\Output\%{iteration}.txt"/> </operator> <connect from_port="single" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Read XML" from_port="output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Filter Documents (by Content)" to_port="documents 1"/> <connect from_op="Filter Documents (by Content)" from_port="documents" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_xml" compatibility="5.3.013" expanded="true" height="60" name="Read XML" width="90" x="45" y="30"> <parameter key="file" value="C:\home\ebrahimi\Anomaly\seg10Train.xml"/> <parameter key="xpath_for_examples" value="conversations/conversation"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="@id"/> <parameter key="xpath_for_attribute" value="message/text"/> <parameter key="xpath_for_attribute" value="message/author"/> </enumeration> <list key="namespaces"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.3.002" expanded="true" height="60" name="Data to Documents" width="90" x="179" y="30"> <parameter key="select_attributes_and_weights" value="true"/> <list key="specify_weights"> <parameter key="tex" value="1.0"/> </list> </operator> <operator activated="true" class="text:filter_documents_by_content" compatibility="5.3.002" expanded="true" height="76" name="Filter Documents (by Content)" width="90" x="313" y="30"> <parameter key="condition" value="contains match"/> <parameter key="regular_expression" value="</text><text>"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.013" expanded="true" height="60" name="Extract Macro" width="90" x="447" y="30"> <parameter key="macro_type" value="data_value"/> <list key="additional_macros"/> </operator> <operator activated="true" class="loop_collection" compatibility="5.3.013" expanded="true" height="76" name="Loop Collection" width="90" x="648" y="30"> <parameter key="set_iteration_macro" value="true"/> <process expanded="true"> <operator activated="true" class="text:write_document" compatibility="5.3.002" expanded="true" height="76" name="Write Document" width="90" x="179" y="30"> <parameter key="file" value="C:\home\ebrahimi\Anomaly\Output\%{mine}.txt"/> </operator> <connect from_port="single" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Read XML" from_port="output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Filter Documents (by Content)" to_port="documents 1"/> <connect from_op="Filter Documents (by Content)" from_port="documents" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
