This paper deals with principally association of 2 attributes where the label is known for all examples. The data is recalculated with filters which are based on values currently considered as standard in medicine.
I do not get how this analysis could be repeated using RM. I know there is some discussion on the use of odds ratio etc.
The reason for my question is the fact I would like to analyse other "associations" of other attributes.
What is the correct terminology for the process used in this article?
Thanks
Sven
https://www.dropbox.com/s/pfh7tm1j2cp1dxd/J%20Intensive%20Care%20Med-2014-Moskowitz-0885066614530659.pdf?dl=0
