<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="6.4.000" expanded="true" height="76" name="Example1 Dataset" width="90" x="45" y="30"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="6.4.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="75"> <parameter key="text" value="PatientID|Attribute|Timestamp 1|att1|26/2/1998 04:02:222 1|att2|26/2/1998 04:02:222 1|att1|26/2/1993 07:02:222 1|att1|26/2/2013 02:42:232"/> </operator> <operator activated="true" class="text:write_document" compatibility="6.4.001" expanded="true" height="76" name="Write Document" width="90" x="179" y="165"/> <operator activated="true" class="read_csv" compatibility="6.4.000" expanded="true" height="60" name="Read CSV" width="90" x="370" y="120"> <parameter key="column_separators" value="|"/> <parameter key="date_format" value="dd/MM/yyyy HH:mm:ss"/> <list key="annotations"/> <list key="data_set_meta_data_information"> <parameter key="0" value="PatientID.true.nominal.attribute"/> <parameter key="1" value="Attribute.true.nominal.attribute"/> <parameter key="2" value="TTimestamp.true.date_time.attribute"/> </list> </operator> <connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="file" to_op="Read CSV" to_port="file"/> <connect from_op="Read CSV" from_port="output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values" width="90" x="179" y="75"> <parameter key="attribute" value="Attribute"/> <parameter key="iteration_macro" value="loop_value_att"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples" width="90" x="45" y="30"> <list key="filters_list"> <parameter key="filters_entry_key" value="Attribute.equals.%{loop_value_att}"/> </list> </operator> <operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values (2)" width="90" x="179" y="75"> <parameter key="attribute" value="PatientID"/> <parameter key="iteration_macro" value="loop_value_pat"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="94" name="Filter Examples (2)" width="90" x="45" y="30"> <list key="filters_list"> <parameter key="filters_entry_key" value="PatientID.equals.%{loop_value_pat}"/> </list> </operator> <operator activated="true" class="sort" compatibility="6.4.000" expanded="true" height="76" name="Sort" width="90" x="179" y="30"> <parameter key="attribute_name" value="TTimestamp"/> </operator> <operator activated="true" class="extract_macro" compatibility="6.4.000" expanded="true" height="60" name="Extract Macro" width="90" x="313" y="75"> <parameter key="macro" value="firstTime"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="TTimestamp"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="210"> <list key="function_descriptions"> <parameter key="AttTime_New_in_milliseconds" value="date_diff(date_parse_custom("%{firstTime}","dd/MM/yyyy HH:mm:ss"),TTimestamp)"/> </list> </operator> <connect from_port="example set" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="313" y="75"/> <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Loop Values (2)" to_port="example set"/> <connect from_op="Loop Values (2)" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append (2)" width="90" x="380" y="75"/> <connect from_op="Example1 Dataset" from_port="out 1" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_op="Append (2)" to_port="example set 1"/> <connect from_op="Append (2)" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
