I have an attribute "time" in my data set, the value is like "2010-03-09T08:51:34", I want to set 5 hours back.
So I did following thing:
- "Nominal to Date", so the attribute will be turned to date format
- "generate attribute", the new attribute has the expression: date_add(time, -5)
but this doesn't work. Error: Invalid number of arguments for 'data_add', must be either 3 or 5.
How can I set 5 hours back for the "time"???
