<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="246" y="75"> <parameter key="report_name" value="A Report Demo"/> <parameter key="format" value="HTML"/> <parameter key="html_output_directory" value="/home/john/Desktop/DemoReport"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="380" y="75"> <parameter key="report_name" value="A Report Demo"/> <parameter key="report_item_header" value="A1 by A2"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Data Table"/> <parameter key="renderer_name" value="Plot View"/> <list key="parameters"> <parameter key="plotter" value="Scatter"/> <parameter key="scatter_axis_x_axis" value="a1"/> <parameter key="scatter_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_axis_y_axis" value="a2"/> <parameter key="scatter_axis_y_axis_log_scale" value="false"/> <parameter key="scatter_plot_column" value="label"/> <parameter key="scatter_jitter_amount" value="0"/> <parameter key="scatter_rotate_labels" value="false"/> <parameter key="scatter_multiple_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_multiple_jitter_amount" value="0"/> <parameter key="scatter_multiple_rotate_labels" value="false"/> <parameter key="scatter_matrix_jitter_amount" value="0"/> <parameter key="bubble_axis_x_axis_log_scale" value="false"/> <parameter key="bubble_rotate_labels" value="false"/> <parameter key="parallel_rotate_labels" value="false"/> <parameter key="parallel_local_normalization" value="false"/> <parameter key="series_rotate_labels" value="false"/> <parameter key="series_multiple_rotate_labels" value="false"/> <parameter key="som_jitter_amount" value="0"/> <parameter key="block_axis_x_axis_log_scale" value="false"/> <parameter key="block_axis_y_axis_log_scale" value="false"/> <parameter key="block_jitter_amount" value="0"/> <parameter key="block_rotate_labels" value="false"/> <parameter key="deviation_rotate_labels" value="false"/> <parameter key="deviation_local_normalization" value="false"/> <parameter key="histogram_absolute_values" value="false"/> <parameter key="histogram_rotate_labels" value="false"/> <parameter key="histogram_log_scale" value="false"/> <parameter key="histogram_number_of_bins" value="40"/> <parameter key="histogram_opaqueness" value="100"/> <parameter key="histogram_color_absolute_values" value="false"/> <parameter key="histogram_color_rotate_labels" value="false"/> <parameter key="histogram_color_log_scale" value="false"/> <parameter key="histogram_color_number_of_bins" value="40"/> <parameter key="histogram_color_opaqueness" value="100"/> <parameter key="bars_absolute_values" value="false"/> <parameter key="bars_rotate_labels" value="false"/> <parameter key="bars_aggregation" value="none"/> <parameter key="bars_use_distinct" value="false"/> <parameter key="bars_orientation" value="vertical"/> <parameter key="bars_stacked_absolute_values" value="false"/> <parameter key="bars_stacked_rotate_labels" value="false"/> <parameter key="bars_stacked_aggregation" value="none"/> <parameter key="bars_stacked_use_distinct" value="false"/> <parameter key="bars_stacked_orientation" value="vertical"/> <parameter key="pareto_rotate_labels" value="false"/> <parameter key="pareto_sorting_direction" value="Descending Keys"/> <parameter key="pareto_show_bar_labels" value="true"/> <parameter key="pareto_show_cumulative_labels" value="false"/> <parameter key="distribution_rotate_labels" value="false"/> <parameter key="web_absolute_values" value="false"/> <parameter key="web_rotate_labels" value="false"/> <parameter key="web_aggregation" value="none"/> <parameter key="web_use_distinct" value="false"/> <parameter key="pie_absolute_values" value="false"/> <parameter key="pie_aggregation" value="none"/> <parameter key="pie_use_distinct" value="false"/> <parameter key="pie_explosion_amount" value="0"/> <parameter key="pie_3d_absolute_values" value="false"/> <parameter key="pie_3d_aggregation" value="none"/> <parameter key="pie_3d_use_distinct" value="false"/> <parameter key="ring_absolute_values" value="false"/> <parameter key="ring_aggregation" value="none"/> <parameter key="ring_use_distinct" value="false"/> <parameter key="ring_explosion_amount" value="0"/> </list> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report (2)" width="90" x="514" y="75"> <parameter key="report_name" value="A Report Demo"/> <parameter key="report_item_header" value="A1 by A3"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Data Table"/> <parameter key="renderer_name" value="Plot View"/> <list key="parameters"> <parameter key="plotter" value="Scatter"/> <parameter key="scatter_axis_x_axis" value="a1"/> <parameter key="scatter_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_axis_y_axis" value="a3"/> <parameter key="scatter_axis_y_axis_log_scale" value="false"/> <parameter key="scatter_plot_column" value="label"/> <parameter key="scatter_jitter_amount" value="0"/> <parameter key="scatter_rotate_labels" value="false"/> <parameter key="scatter_multiple_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_multiple_jitter_amount" value="0"/> <parameter key="scatter_multiple_rotate_labels" value="false"/> <parameter key="scatter_matrix_jitter_amount" value="0"/> <parameter key="bubble_axis_x_axis_log_scale" value="false"/> <parameter key="bubble_rotate_labels" value="false"/> <parameter key="parallel_rotate_labels" value="false"/> <parameter key="parallel_local_normalization" value="false"/> <parameter key="series_rotate_labels" value="false"/> <parameter key="series_multiple_rotate_labels" value="false"/> <parameter key="som_jitter_amount" value="0"/> <parameter key="block_axis_x_axis_log_scale" value="false"/> <parameter key="block_axis_y_axis_log_scale" value="false"/> <parameter key="block_jitter_amount" value="0"/> <parameter key="block_rotate_labels" value="false"/> <parameter key="deviation_rotate_labels" value="false"/> <parameter key="deviation_local_normalization" value="false"/> <parameter key="histogram_absolute_values" value="false"/> <parameter key="histogram_rotate_labels" value="false"/> <parameter key="histogram_log_scale" value="false"/> <parameter key="histogram_number_of_bins" value="40"/> <parameter key="histogram_opaqueness" value="100"/> <parameter key="histogram_color_absolute_values" value="false"/> <parameter key="histogram_color_rotate_labels" value="false"/> <parameter key="histogram_color_log_scale" value="false"/> <parameter key="histogram_color_number_of_bins" value="40"/> <parameter key="histogram_color_opaqueness" value="100"/> <parameter key="bars_absolute_values" value="false"/> <parameter key="bars_rotate_labels" value="false"/> <parameter key="bars_aggregation" value="none"/> <parameter key="bars_use_distinct" value="false"/> <parameter key="bars_orientation" value="vertical"/> <parameter key="bars_stacked_absolute_values" value="false"/> <parameter key="bars_stacked_rotate_labels" value="false"/> <parameter key="bars_stacked_aggregation" value="none"/> <parameter key="bars_stacked_use_distinct" value="false"/> <parameter key="bars_stacked_orientation" value="vertical"/> <parameter key="pareto_rotate_labels" value="false"/> <parameter key="pareto_sorting_direction" value="Descending Keys"/> <parameter key="pareto_show_bar_labels" value="true"/> <parameter key="pareto_show_cumulative_labels" value="false"/> <parameter key="distribution_rotate_labels" value="false"/> <parameter key="web_absolute_values" value="false"/> <parameter key="web_rotate_labels" value="false"/> <parameter key="web_aggregation" value="none"/> <parameter key="web_use_distinct" value="false"/> <parameter key="pie_absolute_values" value="false"/> <parameter key="pie_aggregation" value="none"/> <parameter key="pie_use_distinct" value="false"/> <parameter key="pie_explosion_amount" value="0"/> <parameter key="pie_3d_absolute_values" value="false"/> <parameter key="pie_3d_aggregation" value="none"/> <parameter key="pie_3d_use_distinct" value="false"/> <parameter key="ring_absolute_values" value="false"/> <parameter key="ring_aggregation" value="none"/> <parameter key="ring_use_distinct" value="false"/> <parameter key="ring_explosion_amount" value="0"/> </list> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report (3)" width="90" x="648" y="75"> <parameter key="report_name" value="A Report Demo"/> <parameter key="report_item_header" value="A1 by A4"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Data Table"/> <parameter key="renderer_name" value="Plot View"/> <list key="parameters"> <parameter key="plotter" value="Scatter"/> <parameter key="scatter_axis_x_axis" value="a1"/> <parameter key="scatter_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_axis_y_axis" value="a4"/> <parameter key="scatter_axis_y_axis_log_scale" value="false"/> <parameter key="scatter_plot_column" value="label"/> <parameter key="scatter_jitter_amount" value="0"/> <parameter key="scatter_rotate_labels" value="false"/> <parameter key="scatter_multiple_axis_x_axis_log_scale" value="false"/> <parameter key="scatter_multiple_jitter_amount" value="0"/> <parameter key="scatter_multiple_rotate_labels" value="false"/> <parameter key="scatter_matrix_plot_column" value="a1"/> <parameter key="scatter_matrix_jitter_amount" value="0"/> <parameter key="bubble_axis_x_axis_log_scale" value="false"/> <parameter key="bubble_rotate_labels" value="false"/> <parameter key="parallel_rotate_labels" value="false"/> <parameter key="parallel_local_normalization" value="false"/> <parameter key="series_rotate_labels" value="false"/> <parameter key="series_multiple_rotate_labels" value="false"/> <parameter key="som_jitter_amount" value="0"/> <parameter key="block_axis_x_axis_log_scale" value="false"/> <parameter key="block_axis_y_axis_log_scale" value="false"/> <parameter key="block_jitter_amount" value="0"/> <parameter key="block_rotate_labels" value="false"/> <parameter key="deviation_rotate_labels" value="false"/> <parameter key="deviation_local_normalization" value="false"/> <parameter key="histogram_absolute_values" value="false"/> <parameter key="histogram_rotate_labels" value="false"/> <parameter key="histogram_log_scale" value="false"/> <parameter key="histogram_number_of_bins" value="40"/> <parameter key="histogram_opaqueness" value="100"/> <parameter key="histogram_color_absolute_values" value="false"/> <parameter key="histogram_color_rotate_labels" value="false"/> <parameter key="histogram_color_log_scale" value="false"/> <parameter key="histogram_color_number_of_bins" value="40"/> <parameter key="histogram_color_opaqueness" value="100"/> <parameter key="bars_absolute_values" value="false"/> <parameter key="bars_rotate_labels" value="false"/> <parameter key="bars_aggregation" value="none"/> <parameter key="bars_use_distinct" value="false"/> <parameter key="bars_orientation" value="vertical"/> <parameter key="bars_stacked_absolute_values" value="false"/> <parameter key="bars_stacked_rotate_labels" value="false"/> <parameter key="bars_stacked_aggregation" value="none"/> <parameter key="bars_stacked_use_distinct" value="false"/> <parameter key="bars_stacked_orientation" value="vertical"/> <parameter key="pareto_rotate_labels" value="false"/> <parameter key="pareto_sorting_direction" value="Descending Keys"/> <parameter key="pareto_show_bar_labels" value="true"/> <parameter key="pareto_show_cumulative_labels" value="false"/> <parameter key="distribution_rotate_labels" value="false"/> <parameter key="web_absolute_values" value="false"/> <parameter key="web_rotate_labels" value="false"/> <parameter key="web_aggregation" value="none"/> <parameter key="web_use_distinct" value="false"/> <parameter key="pie_absolute_values" value="false"/> <parameter key="pie_aggregation" value="none"/> <parameter key="pie_use_distinct" value="false"/> <parameter key="pie_explosion_amount" value="0"/> <parameter key="pie_3d_absolute_values" value="false"/> <parameter key="pie_3d_aggregation" value="none"/> <parameter key="pie_3d_use_distinct" value="false"/> <parameter key="ring_absolute_values" value="false"/> <parameter key="ring_aggregation" value="none"/> <parameter key="ring_use_distinct" value="false"/> <parameter key="ring_explosion_amount" value="0"/> </list> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_op="Report (2)" to_port="reportable in"/> <connect from_op="Report (2)" from_port="reportable out" to_op="Report (3)" to_port="reportable in"/> <connect from_op="Report (3)" from_port="reportable out" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
