[SOLVED] nested if statements
User: "sukh"
New Altair Community Member
Updated by Jocelyn
HI all,
i need help in  solving the problem of rapid miner, As i am formulating some rules using nested if. but getting error message.
my rules are as:
two columns: Dtag and Ttag and the result is saved in result column
   Ttag            Dtag        result Column
   present        past            past
   present        present      present
   past             past            past
   past             present        past
   future           past            past
   future           present       future
if(Ttag== “present”, if(Dtag== “past”, “past”, if(Dtag== “present”, “present” , Dtag)),
if(Ttag== “past”, if(Dtag== “past” , “past” , if(Dtag== “present”, “present” , Dtag)),
if(Ttag== “future” , if(Dtag == “past”, “past”, if(Dtag== “present”, “future”, Dtag))))
<process version="6.3.000">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="6.3.000" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="retrieve" compatibility="6.3.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
       <parameter key="repository_entry" value="//Local Repository/CSVDateTime"/>
     <operator activated="true" class="generate_attributes" compatibility="6.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="30">
         <parameter key="AA" value="if(Ttag== “present”, if(Dtag== “past”, “past”, if(Dtag== “present”, “present” , Dtag)),  if(Ttag== “past”, if(Dtag== “past” , “past” , if(Dtag== “present”, “present” , Dtag)), if(Ttag== “future” , if(Dtag == “past”, “past”, if(Dtag== “present”, “future”, Dtag))))"/>
       </list>
     <connect from_op="Retrieve" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
     <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
   </process>
</process>
 Kindly help me.
Thanks and Regards:
Sukh
1 - 4 of 41
    User: "sgenzer"
    Hmm...I don't think that works. I would either use the branch/select sub process operator (setting macros for past, present, future) and then do an if statement in each branch, or use two sets of filter examples in the same way. Either way you will be left with only two choices and can use the if statement, set data, etc...
    Scott
    User: "JEdward"
    Nested If statements can get confusing.  :)
    One way to make it easier to calculate them on RapidMiner is to chain them together as the Generate Attributes operator calculates each expression in series.
    See this as an example.
    <process version="6.4.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
          <operator activated="false" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
          <operator activated="true" class="subprocess" compatibility="6.4.000" expanded="true" height="76" name="Generate Testing Data" width="90" x="179" y="165">
              <operator activated="true" class="text:create_document" compatibility="6.4.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="345">
                <parameter key="text" value="Ttag;Dtag;Expected&#10;present;present;present&#10;present;past;past&#10;past;past;past&#10;past;present;past&#10;future;past;past&#10;future;present;future"/>
              <operator activated="true" class="text:write_document" compatibility="6.4.001" expanded="true" height="76" name="Write Document" width="90" x="112" y="435"/>
              <operator activated="true" class="read_csv" compatibility="6.4.000" expanded="true" height="60" name="Read CSV" width="90" x="246" y="480">
                <list key="annotations"/>
                  <parameter key="0" value="Ttag.true.nominal.attribute"/>
                  <parameter key="1" value="Dtag.true.nominal.attribute"/>
                  <parameter key="2" value="ExpectedResult.true.nominal.attribute"/>
                </list>
              <connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/>
              <connect from_op="Write Document" from_port="file" to_op="Read CSV" to_port="file"/>
              <connect from_op="Read CSV" from_port="output" to_port="out 1"/>
            </process>
          <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="447" y="120">
              <parameter key="AA" value="if(((Ttag == &quot;present&quot;) &amp;&amp; (Dtag == &quot;present&quot;)),&quot;present&quot;,&quot;TBC&quot;)"/>
              <parameter key="AA" value="if(((Ttag == &quot;present&quot;) &amp;&amp; (Dtag == &quot;past&quot;) &amp;&amp; (AA == &quot;TBC&quot;)),&quot;past&quot;,AA)"/>
              <parameter key="AA" value="if(((Ttag == &quot;past&quot;) &amp;&amp; (Dtag == &quot;past&quot;) &amp;&amp; (AA == &quot;TBC&quot;)),&quot;past&quot;,AA)"/>
              <parameter key="AA" value="if(((Ttag == &quot;past&quot;) &amp;&amp; (Dtag == &quot;present&quot;) &amp;&amp; (AA == &quot;TBC&quot;)),&quot;past&quot;,AA)"/>
              <parameter key="AA" value="if(((Ttag == &quot;future&quot;) &amp;&amp; (Dtag == &quot;past&quot;) &amp;&amp; (AA == &quot;TBC&quot;)),&quot;past&quot;,AA)"/>
              <parameter key="AA" value="if(((Ttag == &quot;future&quot;) &amp;&amp; (Dtag == &quot;present&quot;) &amp;&amp; (AA == &quot;TBC&quot;)),&quot;future&quot;,AA)"/>
            </list>
            <description align="center" color="transparent" colored="false" width="126">Generate Attributes executes each calulation in series so you can chain them together.</description>
          <connect from_op="Generate Testing Data" from_port="out 1" to_op="Generate Attributes" to_port="example set input"/>
        </process>
    </process>
    User: "Marco_Boeck"
    you can use nested if functions without problems, however when using such highly nested ones, you must absolutely make sure each function consists of the 3 different parts: The condition, the result for condition = true and the result for condition = false.
    if (condition, valueForTrue, valueForFalse)
    Your expression does not do that, you have multiple if expressions left which do not consist of these 3 parts.
    Simple example:
    <process version="6.5.000-SNAPSHOT">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
          <operator activated="true" class="retrieve" compatibility="6.5.000-SNAPSHOT" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="30">
            <parameter key="repository_entry" value="//Samples/data/Golf"/>
          <operator activated="true" class="generate_attributes" compatibility="6.5.000-SNAPSHOT" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30">
              <parameter key="Temperature_Nominal" value="if (Temperature&lt;=75, &quot;cool&quot;, if (Temperature&gt;=85, &quot;hot&quot;, &quot;medium&quot;))"/>
            </list>
          <connect from_op="Retrieve Golf" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
        </process>
    </process>
    Marco
    User: "sukh"
    OP
    Dear All,
    I have tried using generate attribute with series of expressions, it worked accordingly.
    Thanks alot.
    Regards:
    Sukh
