<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="false" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Local Repository/CSVMaximum"/> </operator> <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="120"> <parameter key="target_function" value="sum"/> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="120"> <list key="function_descriptions"> <parameter key="new" value="if(att1==max(att1,att2,att3),"att1",if(att2==max(att1,att2,att3),"att2",if(att3==max(att1,att2,att3),"att3",0)))"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
