Save Plot VIew Settings
mix2ra
Is it possible to save plot view results settings?
I have defined a flow which outputs in about 19 different result files.
For each result I need to analyse Surface 3D Plot
Every time I open RapidMiner and run the process, I need to setup every plot from the beginning which is very time consuming (19 results * 4 fields to click).
I use RapidMiner 5.3.015 x64 on Windows
Sebastian
Marco_Boeck
you can use the Reporting Extension for that. The plots in Studio itself are not saved, however with the extension you can generate a report (Html, pdf, ...) as the output of your process. You can configure the "Report" operator to take a "Data Table" as the type, change the view to "Plot View" and select your favorite chart as the "plotter". All plot settings are now saved for the report and will be used each time the report is generated.
Marco
