Hi, how are you?
I've been using Decision Tree (Parallel) and I noticed there's a huge difference with using the non-parallel version of the node.
Using exactly the same attributes, parameters and sample, numerical attributes get different splits whenever I run the node again, while the non-parallel version will always produce the same splits and exactly the same trees.
This has something to do with splitting processing in multiple threads, but what is going on exactly?
Check the following process:
You can clearly see the difference between running 3 times a non-parallel and a parallel Decision Tree. You can also change number of threads to 1 and see how the trees become identical.
Thanks for your insight, best regards.
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="multiply" compatibility="5.3.015" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/>
<operator activated="true" class="loop" compatibility="5.3.015" expanded="true" height="76" name="LOOP DT PAR" width="90" x="380" y="120">
<parameter key="iterations" value="3"/>
<operator activated="true" class="parallel:decision_tree_parallel" compatibility="5.3.000" expanded="true" height="76" name="DT PAR" width="90" x="112" y="30">
<parameter key="number_of_threads" value="2"/>
<connect from_port="input 1" to_op="DT PAR" to_port="training set"/>
<connect from_op="DT PAR" from_port="model" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="loop" compatibility="5.3.015" expanded="true" height="76" name="LOOP DT" width="90" x="380" y="30">
<operator activated="true" class="decision_tree" compatibility="5.3.015" expanded="true" height="76" name="DT" width="90" x="179" y="30"/>
<connect from_port="input 1" to_op="DT" to_port="training set"/>
<connect from_op="DT" from_port="model" to_port="output 1"/>
</process>
<connect from_op="Retrieve Iris" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="LOOP DT" to_port="input 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="LOOP DT PAR" to_port="input 1"/>
<connect from_op="LOOP DT PAR" from_port="output 1" to_port="result 2"/>
<connect from_op="LOOP DT" from_port="output 1" to_port="result 1"/>
</process>
</process>
