help on using an existing word list with the process documents operator
VR
For some reason I am unable to make the process documents operator to create a word vector when I feed in an existing word list to it. On running the process, the process documents operator creates a word vector wherein the value of all attributes (supplied by the word list) is zero for all examples. This is impossible as I have created the word list on the same data set. Is there a bug? or am I doing something wrong?
XML pasted below. Thanks for your help!
Regards
V
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="5.3.015" expanded="true" height="60" name="Read Excel" width="90" x="45" y="165">
<parameter key="excel_file" value="C:\Users\Documents\data.xlsx"/>
<parameter key="imported_cell_range" value="A1:P5446"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="ID Auto.true.polynominal.id"/>
<parameter key="3" value="Text.true.text.attribute"/>
</list>
<operator activated="true" class="nominal_to_text" compatibility="5.3.015" expanded="true" height="76" name="Nominal to Text" width="90" x="246" y="165">
<parameter key="attributes" value="|Text"/>
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve word list (2)" width="90" x="514" y="30">
<parameter key="repository_entry" value="//Local Repository/data/word list"/>
<operator activated="true" class="text:data_to_documents" compatibility="5.3.002" expanded="true" height="60" name="Data to Documents" width="90" x="447" y="165">
<list key="specify_weights"/>
<operator activated="true" class="text:process_documents" compatibility="5.3.002" expanded="true" height="94" name="Process Documents" width="90" x="581" y="165">
<parameter key="prune_method" value="percentual"/>
<parameter key="prune_below_percent" value="1.0"/>
<parameter key="prune_above_percent" value="100.0"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="246" y="210"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Retrieve word list (2)" from_port="output" to_op="Process Documents" to_port="word list"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents" from_port="word list" to_port="result 2"/>
</process>
</process>
Text Mining + NLP
VR
Further information on my earlier post. I see that I have a problem only when I try to create a TF-IDF vector. I get non-zero values for all others (Term Frequency, etc.)
Thanks
Vidya
MartinLiebig
are you doing exactly the same things inside Process Documents? Both have just a tokenize inside?
Cheers,
Martin
VR
Hi Martin,
No I am not using the same tokenize - I cannot do so - because here is how I do it
1. In the first step, I tokenize and extract a word list - 1 from the data set
2. Subsequently, I only want to use select parts of speech words to generate a vector, so I have written the word list - 1 from step 1 to a file and run a POS tokenize on this word list - 1 to extract a sub-set of tokens in a word list -2.
3. The process that I sent to you uses this word-list 2 and gives me zero values for TF-IDF vector for the same data set as in step 1. Interestingly I tried using Generate TF-IDF operator after process operator (but then generating a TF- vector) and I do get non-zero values
Let me know if this is unclear and thanks for your help!
Regards
V
