hi everyone,
not sure if the logic of what i'm doing is right, so here is the problem:
- i generated sequences of nominal values which i want to compare with a test sequence
- i want to use a loop to run different distance measures
- then collate the whole thing in a single table for exporting
the first script does it with separate streams/processes and then i join them (i'll have to post this separate because of the char limit)
the second one tries to do the same using a loop parameter block, but i don't seem to be able to make it work (see below)
<process version="6.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" breakpoints="after" class="subprocess" compatibility="6.3.000" expanded="true" height="112" name="Subprocess" width="90" x="45" y="120">
<operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="380" y="30">
<list key="attribute_values">
<parameter key="att1" value="1"/>
<parameter key="att2" value="2"/>
<parameter key="att3" value="3"/>
<parameter key="att4" value="4"/>
<parameter key="att5" value="5"/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30">
</list>
<operator activated="true" class="loop" compatibility="6.3.000" expanded="true" height="76" name="Loop" width="90" x="246" y="300">
<parameter key="iterations" value="100"/>
<operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification (4)" width="90" x="179" y="30">
<parameter key="att1" value="floor((rand()*9))"/>
<parameter key="att2" value="floor((rand()*9))"/>
<parameter key="att3" value="floor((rand()*9))"/>
<parameter key="att4" value="floor((rand()*9))"/>
<parameter key="att5" value="floor((rand()*9))"/>
</list>
<connect from_op="Generate Data by User Specification (4)" from_port="output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="generate_id" compatibility="6.3.000" expanded="true" height="76" name="Generate ID" width="90" x="514" y="30">
<parameter key="create_nominal_ids" value="true"/>
<operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="120">
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification (5)" width="90" x="45" y="210">
<parameter key="att2" value="3"/>
<parameter key="att3" value="2"/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification (6)" width="90" x="45" y="300">
<parameter key="att4" value="6"/>
<parameter key="att5" value="7"/>
</list>
<operator activated="true" class="append" compatibility="6.3.000" expanded="true" height="148" name="Append" width="90" x="246" y="75"/>
<operator activated="true" class="generate_id" compatibility="6.3.000" expanded="true" height="76" name="Generate ID (2)" width="90" x="514" y="120">
<connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/>
<connect from_op="Loop" from_port="output 1" to_op="Append" to_port="example set 5"/>
<connect from_op="Generate ID" from_port="example set output" to_port="out 1"/>
<connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/>
<connect from_op="Generate Data by User Specification (5)" from_port="output" to_op="Append" to_port="example set 3"/>
<connect from_op="Generate Data by User Specification (6)" from_port="output" to_op="Append" to_port="example set 4"/>
<connect from_op="Append" from_port="merged set" to_op="Generate ID (2)" to_port="example set input"/>
<connect from_op="Generate ID (2)" from_port="example set output" to_port="out 2"/>
<portSpacing port="sink_out 2" spacing="162"/>
<portSpacing port="sink_out 3" spacing="0"/>
<portSpacing port="sink_out 4" spacing="0"/>
</process>
<operator activated="true" class="multiply" compatibility="6.3.000" expanded="true" height="76" name="Multiply (2)" width="90" x="179" y="210"/>
<operator activated="true" class="multiply" compatibility="6.3.000" expanded="true" height="76" name="Multiply" width="90" x="179" y="75"/>
<operator activated="true" class="loop_parameters" compatibility="6.3.000" expanded="true" height="94" name="Loop Parameters" width="90" x="447" y="210">
<list key="parameters">
<parameter key="Cross Distances (2).numerical_measure" value="EuclideanDistance,CamberraDistance,ManhattanDistance"/>
</list>
<operator activated="true" class="cross_distances" compatibility="6.3.000" expanded="true" height="94" name="Cross Distances (2)" width="90" x="112" y="120"/>
<operator activated="true" class="generate_macro" compatibility="6.3.000" expanded="true" height="76" name="Generate Macro" width="90" x="313" y="120">
<parameter key="colName" value="%{iteration}_model"/>
</list>
<operator activated="true" class="generate_id" compatibility="6.3.000" expanded="true" height="76" name="Generate ID (4)" width="90" x="447" y="120">
<operator activated="true" class="rename" compatibility="6.3.000" expanded="true" height="76" name="Rename (2)" width="90" x="581" y="120">
<parameter key="old_name" value="distance"/>
<parameter key="new_name" value="%{colName}"/>
<list key="rename_additional_attributes"/>
<connect from_port="input 1" to_op="Cross Distances (2)" to_port="request set"/>
<connect from_port="input 2" to_op="Cross Distances (2)" to_port="reference set"/>
<connect from_op="Cross Distances (2)" from_port="result set" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Generate ID (4)" to_port="example set input"/>
<connect from_op="Generate ID (4)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/>
<connect from_op="Rename (2)" from_port="example set output" to_port="performance"/>
<portSpacing port="source_input 3" spacing="0"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="Subprocess" from_port="out 1" to_op="Multiply" to_port="input"/>
<connect from_op="Subprocess" from_port="out 2" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Subprocess" from_port="out 3" to_port="result 1"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Loop Parameters" to_port="input 2"/>
<connect from_op="Multiply" from_port="output 1" to_op="Loop Parameters" to_port="input 1"/>
<connect from_op="Loop Parameters" from_port="result 1" to_port="result 2"/>
</process>
</process>
any suggestion will be very much appreciated!
Lorenzo
