<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.3.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.3.000" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="255"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="naive_bayes" compatibility="6.3.000" expanded="true" height="76" name="Naive Bayes" width="90" x="112" y="75"/> <operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="246" y="75"> <parameter key="report_name" value="demo_naivebayes"/> <parameter key="format" value="HTML"/> <parameter key="repository_entry" value="//Local Repository/processes/demo"/> <parameter key="html_output_directory" value="ENTER YOUR OUTPUT DIRECTORY HERE"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="246" y="210"> <parameter key="report_name" value="demo_naivebayes"/> <parameter key="report_item_header" value="demo_description"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Distribution Model"/> <parameter key="renderer_name" value="Text View"/> <list key="parameters"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report (2)" width="90" x="313" y="345"> <parameter key="report_name" value="demo_naivebayes"/> <parameter key="report_item_header" value="distribution_att1"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Distribution Model"/> <parameter key="renderer_name" value="Plot View"/> <list key="parameters"> <parameter key="attribute_name" value="attribute_1"/> <parameter key="range_" value="."/> <parameter key="rotate_labels" value="false"/> </list> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_op="Report (2)" to_port="reportable in"/> <connect from_op="Report (2)" from_port="reportable out" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
