I have a process chain which takes in documents from files and does some preprocessing on them. This is given as input to the validator which has a modelling operator. I am not able to use SVM here. Could you please tell me how can I use SVM here?
<?xml version="1.0" encoding="UTF-8" standalone="no"?> I am attaching my process XML here.
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="bus_stop" value="C:\Users\w44ylqrl\Citizen\Data\bmtc\categories\bus_stop"/>
<parameter key="crew_misbehaviour" value="C:\Users\w44ylqrl\Citizen\Data\bmtc\categories\crew_misbehaviour"/>
<parameter key="frequency" value="C:\Users\w44ylqrl\Citizen\Data\bmtc\categories\frequency"/>
<parameter key="shelter" value="C:\Users\w44ylqrl\Citizen\Data\bmtc\categories\shelter"/>
</list>
<parameter key="datamanagement" value="double_array"/>
<operator activated="true" class="text:filter_tokens_by_pos" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="45" y="30">
<parameter key="expression" value="NNP.*"/>
<parameter key="invert_filter" value="true"/>
<operator activated="true" class="text:replace_tokens" compatibility="5.3.002" expanded="true" height="60" name="Replace Tokens (2)" width="90" x="180" y="30">
<list key="replace_dictionary">
<parameter key="(https|http|ftp|file)://[-a-zA-Z0-9+&
@#/%?=~_|!:,.;]*[-a-zA-Z0-9+&
@#/%=~_|]" value="="/>
<parameter key="&amp;" value="="/>
<parameter key="
@[-a-zA-Z0-9+&amp;
@#/%?=~_|!:,.;]*" value="="/>
<parameter key="[^A-Za-z]" value="="/>
<parameter key="\s[\s]+" value="="/>
</list>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="315" y="30">
<parameter key="characters" value=". " ! ? -"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (2)" width="90" x="450" y="30"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.002" expanded="true" height="76" name="Filter Stopwords (Dictionary)" width="90" x="45" y="120">
<parameter key="file" value="C:\Users\w44ylqrl\CitiZen_Java\org.xerox.citizen.categorizzation\data\stopWordList2.csv"/>
<operator activated="true" class="text:remove_document_parts" compatibility="5.3.002" expanded="true" height="60" name="Remove Document Parts" width="90" x="180" y="120">
<parameter key="deletion_regex" value="="/>
<operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="315" y="120"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.002" expanded="true" height="76" name="Filter Stopwords (2)" width="90" x="447" y="120">
<parameter key="file" value="C:\Users\w44ylqrl\CitiZen_Java\org.xerox.citizen.categorizzation\data\correctedDomainWords.csv"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (3)" width="90" x="45" y="255">
<parameter key="max_chars" value="15"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.3.002" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="447" y="255">
<parameter key="max_length" value="3"/>
<connect from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_op="Replace Tokens (2)" to_port="document"/>
<connect from_op="Replace Tokens (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
<connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Remove Document Parts" to_port="document"/>
<connect from_op="Remove Document Parts" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Tokens (3)" to_port="document"/>
<connect from_op="Filter Tokens (3)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes" width="90" x="246" y="210">
<parameter key="attribute_filter_type" value="no_missing_values"/>
<operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role" width="90" x="380" y="210">
<parameter key="attribute_name" value="label"/>
<operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="130" name="Validation" width="90" x="313" y="480">
<operator activated="true" class="support_vector_machine_linear" compatibility="5.3.013" expanded="true" height="76" name="SVM (Linear)" width="90" x="112" y="300"/>
<connect from_port="training" to_op="SVM (Linear)" to_port="training set"/>
<connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="174" y="30">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
<portSpacing port="sink_averagable 3" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Process Documents from Files (2)" to_port="word list"/>
<connect from_op="Process Documents from Files (2)" from_port="example set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Process Documents from Files (2)" from_port="word list" to_port="result 1"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 2"/>
<connect from_op="Validation" from_port="training" to_port="result 3"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 4"/>
<connect from_op="Validation" from_port="averagable 2" to_port="result 5"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
</process>
</process>
