<operator activated="true" class="generate_macro" compatibility="6.3.000" expanded="true" height="76" name="Generate Macro (3)" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="Test_Type_Test_Num" value="if(matches("%{Test_Type_Test}","Process"),round(1),if(matches("%{Test_Type_Test}","Aspect"),round(2),round(3)))"/> </list> </operator> <operator activated="true" class="generate_macro" compatibility="6.3.000" expanded="true" height="76" name="Generate Macro (6)" width="90" x="313" y="120"> <list key="function_descriptions"> <parameter key="Selector" value="str(%{Test_Type_Test_Num})"/> </list> </operator> <operator activated="true" class="select_subprocess" compatibility="6.3.000" expanded="true" height="76" name="Select Subprocess" width="90" x="447" y="120"> <parameter key="select_which" value="%{Selector}"/> <parameter key="parallelize_selection_1" value="true"/> <parameter key="parallelize_selection_2" value="true"/> <process expanded="true"></operator>
<operator activated="true" class="subprocess" compatibility="6.3.000" expanded="true" height="76" name="Get files" width="90" x="45" y="345"> <process expanded="true"> <operator activated="true" class="loop_files" compatibility="6.3.000" expanded="true" height="76" name="Set file directory" width="90" x="112" y="30"> <parameter key="directory" value="%{FolderDirectory}"/> <parameter key="filter" value="Ass.*.csv|Class.*.csv|Spec.*.csv|Stud.*.csv"/> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="179" y="30"> <list key="attribute_values"> <parameter key="FileName" value=""%{file_name}""/> </list> <list key="set_additional_roles"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_port="out 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.3.000" expanded="true" height="76" name="Append (3)" width="90" x="246" y="30"/> <operator activated="true" class="generate_copy" compatibility="6.3.000" expanded="true" height="76" name="Generate Copy of FileName" width="90" x="380" y="30"> <parameter key="attribute_name" value="FileName"/> <parameter key="new_name" value="Selector"/> </operator> <operator activated="true" class="map" compatibility="6.3.000" expanded="true" height="76" name="Create Selector Numbers" width="90" x="514" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Selector"/> <list key="value_mappings"> <parameter key="AssessmentResults.csv" value="2"/> <parameter key="ClassAssignments.csv" value="3"/> <parameter key="StudentBySchool.csv" value="4"/> <parameter key="SpecialProgramAssignments.csv" value="5"/> </list> <parameter key="replace_what" value="AccommodationAssignment.csv"/> <parameter key="replace_by" value="1"/> </operator> <operator activated="true" class="loop_values" compatibility="6.3.000" expanded="true" height="76" name="Loop Values" width="90" x="648" y="30"> <parameter key="attribute" value="FileName"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="6.3.000" expanded="true" height="94" name="Filter FileName" width="90" x="45" y="30"> <list key="filters_list"> <parameter key="filters_entry_key" value="FileName.equals.%{loop_value}"/> </list> </operator> <operator activated="true" class="extract_macro" compatibility="6.3.000" expanded="true" height="60" name="Extract FileName" width="90" x="179" y="30"> <parameter key="macro" value="FileName"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="FileName"/> <parameter key="example_index" value="1"/> <list key="additional_macros"> <parameter key="Selector" value="Selector"/> </list> </operator> <operator activated="true" class="select_subprocess" compatibility="6.3.000" expanded="true" height="76" name="Select Import CSV schema" width="90" x="313" y="30"> <parameter key="select_which" value="%{Selector}"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="6.3.000" expanded="true" height="60" name="Read new AccommodationAssignment (2)" width="90" x="45" y="30"> <parameter key="csv_file" value="%{parent_path}/AccommodationAssignment.csv"/> <parameter key="column_separators" value=","/> <parameter key="date_format" value="MM/dd/yyyy"/> <list key="annotations"/> <list key="data_set_meta_data_information"> <parameter key="0" value="TermName.false.nominal.attribute"/> <parameter key="1" value="AssessmentGUID.true.polynominal.attribute"/> <parameter key="2" value="StudentIdentifier.true.nominal.id"/> <parameter key="3" value="AssessmentAccommodationCategory.true.polynominal.attribute"/> <parameter key="4" value="AssessmentAccommodationType.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="remember" compatibility="6.3.000" expanded="true" height="60" name="Remember AccommodationAssignment" width="90" x="45" y="120"> <parameter key="name" value="AccommodationAssignment"/> </operator> <connect from_op="Read new AccommodationAssignment (2)" from_port="output" to_op="Remember AccommodationAssignment" to_port="store"/> <connect from_op="Remember AccommodationAssignment" from_port="stored" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process>
