<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="6.1.000" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="This is a document. Its length is sufficient to pass the following "Filter Examples" operator."/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="6.1.000" expanded="true" height="76" name="Documents to Data" width="90" x="179" y="30"> <parameter key="text_attribute" value="text"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000-SNAPSHOT" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="length" value="length(text)"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="6.4.000-SNAPSHOT" expanded="true" height="94" name="Filter Examples" width="90" x="447" y="30"> <list key="filters_list"> <parameter key="filters_entry_key" value="length.ge.50"/> </list> <parameter key="filters_check_metadata" value="false"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="6.1.000" expanded="true" height="60" name="Data to Documents" width="90" x="581" y="30"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:create_document" compatibility="6.1.000" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="165"> <parameter key="text" value="Too short"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="6.1.000" expanded="true" height="76" name="Documents to Data (2)" width="90" x="179" y="165"> <parameter key="text_attribute" value="text"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000-SNAPSHOT" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="313" y="165"> <list key="function_descriptions"> <parameter key="length" value="length(text)"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="6.4.000-SNAPSHOT" expanded="true" height="94" name="Filter Examples (2)" width="90" x="447" y="165"> <list key="filters_list"> <parameter key="filters_entry_key" value="length.ge.50"/> </list> <parameter key="filters_check_metadata" value="false"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="6.1.000" expanded="true" height="60" name="Data to Documents (2)" width="90" x="581" y="165"> <list key="specify_weights"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_port="result 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Documents to Data (2)" to_port="documents 1"/> <connect from_op="Documents to Data (2)" from_port="example set" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Data to Documents (2)" to_port="example set"/> <connect from_op="Data to Documents (2)" from_port="documents" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="6.1.000" expanded="true" height="60" name="Create Document" width="90" x="112" y="75"> <parameter key="text" value="This is a long sentence that is more than 25 characters in length"/> </operator> <operator activated="true" class="text:create_document" compatibility="6.1.000" expanded="true" height="60" name="Create Document (2)" width="90" x="112" y="210"> <parameter key="text" value="short"/> </operator> <operator activated="true" class="text:create_document" compatibility="6.1.000" expanded="true" height="60" name="Create Document (3)" width="90" x="112" y="345"> <parameter key="text" value="this is medium length"/> </operator> <operator activated="true" class="text:combine_documents" compatibility="6.1.000" expanded="true" height="112" name="Combine Documents" width="90" x="313" y="75"/> <operator activated="true" class="text:filter_by_length" compatibility="6.1.000" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="447" y="75"> <parameter key="min_chars" value="10"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Combine Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Combine Documents" to_port="documents 2"/> <connect from_op="Create Document (3)" from_port="output" to_op="Combine Documents" to_port="documents 3"/> <connect from_op="Combine Documents" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
