ok this is fun. Here's pulling home information via the Zillow API into RM for analysis. Again you will need to create your own Zillow API key (called zws-id).
<process version="6.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:create_document" compatibility="6.1.000" expanded="true" height="60" name="Create Document" width="90" x="45" y="30">
<parameter key="text" value="198 Kerwin Hill Road"/>
<operator activated="true" class="text:documents_to_data" compatibility="6.1.000" expanded="true" height="76" name="Documents to Data" width="90" x="179" y="30">
<parameter key="text_attribute" value="address"/>
<operator activated="true" class="generate_attributes" compatibility="6.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="30">
<parameter key="citystatezip" value=""Norwich VT 05055""/>
</list>
<operator activated="true" class="web:encode_urls" compatibility="5.3.002" expanded="true" height="76" name="Encode URLs" width="90" x="447" y="30">
<parameter key="url_attribute" value="address"/>
<operator activated="true" class="web:encode_urls" compatibility="5.3.002" expanded="true" height="76" name="Encode URLs (2)" width="90" x="581" y="30">
<parameter key="url_attribute" value="citystatezip"/>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="5.3.002" expanded="true" height="60" name="Enrich Data by Webservice" width="90" x="715" y="30">
<parameter key="query_type" value="XPath"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries">
<parameter key="zpid" value="//zpid/text()"/>
<parameter key="lastSoldDate" value="//lastSoldDate/text()"/>
<parameter key="lastSoldPrice" value="//lastSoldPrice/text()"/>
<parameter key="lotSizeSqFt" value="//lotSizeSqFt/text()"/>
</list>
<list key="namespaces"/>
<parameter key="assume_html" value="false"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<parameter key="url" value="http://www.zillow.com/webservice/GetDeepSearchResults.htm?zws-id=ENTER KEY HERE&address=<%address%>&citystatezip=<%citystatezip%>"/>
<list key="request_properties"/>
<connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/>
<connect from_op="Documents to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Encode URLs" to_port="example set input"/>
<connect from_op="Encode URLs" from_port="example set output" to_op="Encode URLs (2)" to_port="example set input"/>
<connect from_op="Encode URLs (2)" from_port="example set output" to_op="Enrich Data by Webservice" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_port="result 1"/>
</process>
</process>
