<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.3.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.3.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="120"> <list key="attribute_values"> <parameter key="id1" value="1"/> <parameter key="id2" value="2"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_id" compatibility="6.3.000" expanded="true" height="76" name="Generate ID" width="90" x="179" y="75"/> <operator activated="true" class="multiply" compatibility="6.3.000" expanded="true" height="94" name="Multiply (2)" width="90" x="179" y="210"/> <operator activated="true" class="append" compatibility="6.3.000" expanded="true" height="94" name="Append (2)" width="90" x="313" y="210"/> <operator activated="true" class="set_data" compatibility="6.3.000" expanded="true" height="76" name="Set Data" width="90" x="447" y="120"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="id1"/> <parameter key="value" value="2"/> <list key="additional_values"> <parameter key="id2" value="1"/> </list> </operator> <operator activated="true" class="multiply" compatibility="6.3.000" expanded="true" height="94" name="Multiply" width="90" x="581" y="120"/> <operator activated="true" class="rename" compatibility="6.3.000" expanded="true" height="76" name="Rename" width="90" x="715" y="30"> <parameter key="old_name" value="id1"/> <parameter key="new_name" value="test_id1"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="rename" compatibility="6.3.000" expanded="true" height="76" name="Rename (2)" width="90" x="849" y="30"> <parameter key="old_name" value="id2"/> <parameter key="new_name" value="test_id2"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="rename" compatibility="6.3.000" expanded="true" height="76" name="Rename (3)" width="90" x="715" y="165"> <parameter key="old_name" value="id2"/> <parameter key="new_name" value="test_id1"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="rename" compatibility="6.3.000" expanded="true" height="76" name="Rename (4)" width="90" x="849" y="165"> <parameter key="old_name" value="id1"/> <parameter key="new_name" value="test_id2"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="append" compatibility="6.3.000" expanded="true" height="94" name="Append" width="90" x="983" y="120"/> <operator activated="true" class="remove_duplicates" compatibility="6.3.000" expanded="true" height="76" name="Remove Duplicates" width="90" x="1117" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="test_id1|test_id2"/> </operator> <operator activated="true" class="remove_duplicates" compatibility="6.3.000" expanded="true" height="76" name="Remove Duplicates (2)" width="90" x="1251" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value="test_id1|test_id2"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Append (2)" to_port="example set 2"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Append (2)" to_port="example set 1"/> <connect from_op="Append (2)" from_port="merged set" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Rename" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Rename (3)" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Rename (3)" from_port="example set output" to_op="Rename (4)" to_port="example set input"/> <connect from_op="Rename (4)" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Remove Duplicates (2)" to_port="example set input"/> <connect from_op="Remove Duplicates (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
