<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="6.1.000" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="Hello! Small example for document processing with the "Execute Script" operator!"/> </operator> <operator activated="true" class="text:tokenize" compatibility="6.1.000" expanded="true" height="60" name="Tokenize" width="90" x="179" y="30"/> <operator activated="true" class="execute_script" compatibility="6.4.000-SNAPSHOT" expanded="true" height="76" name="Execute Script" width="90" x="313" y="30"> <parameter key="script" value="import com.rapidminer.operator.text.Document; import com.rapidminer.operator.text.Token; import java.util.List; import java.util.LinkedList; Document doc = input[0]; int counter = 0; List<Token> newTokens = new LinkedList<>(); for (Token token : doc.getTokenSequence()) { 	Token nToken = new Token(counter + ": " + token.getToken(), token); 	newTokens.add(nToken); 	counter++; } doc.setTokenSequence(newTokens); return doc;"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Execute Script" to_port="input 1"/> <connect from_op="Execute Script" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
