I have a Gradle Project where I develop my Java application. Now I wanted to use RM as library in my project. For this I needed to change my gradle.build file so that I can access the com.rapidminer.gradle-plugin.
I extended the gradle.build file according to the buildscript snippet here:
https://plugins.gradle.org/plugin/com.rapidminer.gradle-plugin.But unfortunately i get the following errors when I refresh the dependencies:
Failed to notify ProjectEvaluationListener.afterEvaluate(), but primary configuration failure takes precedence.
org.gradle.listener.ListenerNotificationException: Failed to notify project evaluation listener.
at org.gradle.listener.BroadcastDispatch.dispatch(BroadcastDispatch.java:94)
at org.gradle.listener.BroadcastDispatch.dispatch(BroadcastDispatch.java:31)
at org.gradle.messaging.dispatch.ProxyDispatchAdapter$DispatchingInvocationHandler.invoke(ProxyDispatchAdapter.java:93)
at com.sun.proxy.$Proxy13.afterEvaluate(Unknown Source)
at org.gradle.configuration.project.LifecycleProjectEvaluator.notifyAfterEvaluate(LifecycleProjectEvaluator.java:67)
at org.gradle.configuration.project.LifecycleProjectEvaluator.evaluate(LifecycleProjectEvaluator.java:61)
at org.gradle.api.internal.project.AbstractProject.evaluate(AbstractProject.java:521)
at org.gradle.api.internal.project.AbstractProject.evaluate(AbstractProject.java:82)
at org.gradle.configuration.DefaultBuildConfigurer.configure(DefaultBuildConfigurer.java:31)
at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java:129)
at org.gradle.initialization.DefaultGradleLauncher.doBuild(DefaultGradleLauncher.java:106)
at org.gradle.initialization.DefaultGradleLauncher.getBuildAnalysis(DefaultGradleLauncher.java:97)
at org.gradle.launcher.exec.InProcessBuildActionExecuter$DefaultBuildController.configure(InProcessBuildActionExecuter.java:84)
at org.gradle.tooling.internal.provider.BuildModelAction.run(BuildModelAction.java:53)
at org.gradle.tooling.internal.provider.BuildModelAction.run(BuildModelAction.java:32)
at org.gradle.tooling.internal.provider.ConfiguringBuildAction.run(ConfiguringBuildAction.java:134)
at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:36)
at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:26)
at org.gradle.launcher.daemon.server.exec.ExecuteBuild.doBuild(ExecuteBuild.java:47)
at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:34)
at org.gradle.launcher.daemon.server.exec.DaemonCommandExecution.proceed(DaemonCommandExecution.java:125)
at org.gradle.launcher.daemon.server.exec.WatchForDisconnection.execute(WatchForDisconnection.java:35)
at org.gradle.launcher.daemon.server.exec.ResetDeprecationLogger.execute(ResetDeprecationLogger.java:24)
at org.gradle.launcher.daemon.server.exec.StartStopIfBuildAndStop.execute(StartStopIfBuildAndStop.java:33)
at org.gradle.launcher.daemon.server.exec.ReturnResult.execute(ReturnResult.java:34)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:71)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:69)
at org.gradle.util.Swapper.swap(Swapper.java:38)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput.execute(ForwardClientInput.java:69)
at org.gradle.launcher.daemon.server.exec.LogToClient.doBuild(LogToClient.java:60)
at org.gradle.launcher.daemon.server.exec.EstablishBuildEnvironment.doBuild(EstablishBuildEnvironment.java:70)
at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy$1.run(StartBuildOrRespondWithBusy.java:45)
at org.gradle.launcher.daemon.server.DaemonStateCoordinator.runCommand(DaemonStateCoordinator.java:258)
at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy.doBuild(StartBuildOrRespondWithBusy.java:49)
at org.gradle.launcher.daemon.server.exec.HandleCancel.execute(HandleCancel.java:36)
at org.gradle.launcher.daemon.server.exec.HandleStop.execute(HandleStop.java:30)
at org.gradle.launcher.daemon.server.exec.DaemonHygieneAction.execute(DaemonHygieneAction.java:39)
at org.gradle.launcher.daemon.server.exec.CatchAndForwardDaemonFailure.execute(CatchAndForwardDaemonFailure.java:32)
at org.gradle.launcher.daemon.server.exec.DefaultDaemonCommandExecuter.executeCommand(DefaultDaemonCommandExecuter.java:52)
at org.gradle.launcher.daemon.server.DefaultIncomingConnectionHandler$ConnectionWorker.handleCommand(DefaultIncomingConnectionHandler.java:154)
at org.gradle.launcher.daemon.server.DefaultIncomingConnectionHandler$ConnectionWorker.receiveAndHandleCommand(DefaultIncomingConnectionHandler.java:128)
at org.gradle.launcher.daemon.server.DefaultIncomingConnectionHandler$ConnectionWorker.run(DefaultIncomingConnectionHandler.java:116)
at org.gradle.internal.concurrent.DefaultExecutorFactory$StoppableExecutorImpl$1.run(DefaultExecutorFactory.java:64)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Cause 1: java.lang.NullPointerException
Cause 2: groovy.lang.MissingPropertyException: Could not find property 'bintrayUser' on com.jfrog.bintray.gradle.BintrayExtension_Decorated@40fc4271.
at org.gradle.api.internal.AbstractDynamicObject.propertyMissingException(AbstractDynamicObject.java:43)
at org.gradle.api.internal.AbstractDynamicObject.getProperty(AbstractDynamicObject.java:35)
at org.gradle.api.internal.CompositeDynamicObject.getProperty(CompositeDynamicObject.java:94)
at com.jfrog.bintray.gradle.BintrayExtension_Decorated.getProperty(Unknown Source)
at org.codehaus.groovy.runtime.InvokerHelper.getProperty(InvokerHelper.java:168)
at groovy.lang.Closure.getPropertyTryThese(Closure.java:321)
at groovy.lang.Closure.getPropertyDelegateFirst(Closure.java:311)
at groovy.lang.Closure.getProperty(Closure.java:296)
at org.codehaus.groovy.runtime.callsite.PogoGetPropertySite.getProperty(PogoGetPropertySite.java:47)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGroovyObjectGetProperty(AbstractCallSite.java:231)
at com.rapidminer.gradle.RapidMinerGradlePlugin$_apply_closure1_closure7_closure20.doCall(RapidMinerGradlePlugin.groovy:122)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:324)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:278)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1016)
at groovy.lang.Closure.call(Closure.java:423)
at groovy.lang.Closure.call(Closure.java:439)
at org.gradle.api.internal.ClosureBackedAction.execute(ClosureBackedAction.java:59)
at org.gradle.api.internal.plugins.ExtensionsStorage$ExtensionHolder.configure(ExtensionsStorage.java:145)
at org.gradle.api.internal.plugins.ExtensionsStorage.configureExtension(ExtensionsStorage.java:69)
at org.gradle.api.internal.plugins.DefaultConvention$ExtensionsDynamicObject.invokeMethod(DefaultConvention.java:207)
at org.gradle.api.internal.CompositeDynamicObject.invokeMethod(CompositeDynamicObject.java:147)
at org.gradle.api.internal.project.DefaultProject_Decorated.invokeMethod(Unknown Source)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeOnDelegationObjects(ClosureMetaClass.java:414)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:355)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:807)
at groovy.lang.GroovyObjectSupport.invokeMethod(GroovyObjectSupport.java:44)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:353)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:66)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:49)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:133)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141)
at com.rapidminer.gradle.RapidMinerGradlePlugin$_apply_closure1_closure7.doCall(RapidMinerGradlePlugin.groovy:121)
at org.gradle.listener.ClosureBackedMethodInvocationDispatch.dispatch(ClosureBackedMethodInvocationDispatch.java:40)
at org.gradle.listener.ClosureBackedMethodInvocationDispatch.dispatch(ClosureBackedMethodInvocationDispatch.java:25)
at org.gradle.listener.BroadcastDispatch.dispatch(BroadcastDispatch.java:83)
FAILURE: Build failed with an exception.
* What went wrong:
A problem occurred configuring root project 'rapidminer.project'.
> Exception thrown while executing model rule: org.gradle.api.publish.plugins.PublishingPlugin$Rules#publishing(org.gradle.api.plugins.ExtensionContainer)
> Could not find property 'artifactory_contextUrl' on org.gradle.api.internal.artifacts.repositories.DefaultMavenArtifactRepository_Decorated@7f62e325.
I am very new in Gradle and Rapidminer and would appreciate any help! thanks!
