Hi all,
How to export contact force in a frequency response analysis ?I can't found related options in Results Request.
The Contact force result request is not supported for Modal frequency response analysis.
Please find the attached OptiStruct document for your reference.
https://2023.help.altair.com/2023.1/hwsolvers/os/topics/solvers/os/contf_io_r.htm
Thanks & Regards,
Santhoshkumar
Hello, The Contact force result request is not supported for Modal frequency response analysis. Please find the attached OptiStruct document for your reference. https://2023.help.altair.com/2023.1/hwsolvers/os/topics/solvers/os/contf_io_r.htm Thanks & Regards, Santhoshkumar
Is there any alternative method to output contact force in modal frequency response analysis?
This is now possible in the 2025.1
