Hi, I am trying to install and start/run at least two rapidminer server installations on the same machine. The setup wizards run fine. Starting the servers at the command line looks fine.
I have different url´s for both:
http://10.10.100.22:8085/RA/faces/login.xhtmlhttp://10.10.100.22:8080/RA/faces/login.xhtmlNote: They work fine when not started/running together.
They just don´t seem to want to run at the same time. I am guessing this has to be with some configuration of other kind ports for other services ? some other stuff?
Can someone give me suggestion/instructions on what to do or what is going on? A list of port mappings and where to change them for each server instance?
Thank you
Addiel de Alba
