Edit #2: I got RapidMiner started by going through the start menu instead of its quick launch icon (which had worked until today for some reason). I also can now get text analysis results (I had mistakenly forgotten to leave ‘prune method’ = none.
Hi folks. I followed the steps listed here (
http://auburnbigdata.blogspot.ca/2013/03/text-processing-tutorial-with-rapidminer.html) for doing basic processing of a text document. In my case, I'm trying a simple 1-page text document. I can open the document but can't process it.
My setup (main process and vector creation) looks identical to the pictures in the blog post and RapidMiner runs, but the results window is empty. When I checked the <Problems> window, it reports ‘No problems found.’
I'm using RapidMiner studio 6.2.
Ideas?
Thank you in advance
p.s. Since posting this, RapidMiner has stopped loading. I get an error message ‘Java could not be launched. Probably there is not enough free memory …’ (There is actually > 10GB of available memory, according to Windows).
