<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="6.2.000" expanded="true" height="60" name="Read Excel" width="90" x="112" y="30"> <parameter key="excel_file" value="C:\Users\Martin\Downloads\Example data.xls"/> <parameter key="imported_cell_range" value="A1:F17"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Comment"/> <parameter key="1" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="House.true.polynominal.attribute"/> <parameter key="1" value="Category.true.polynominal.attribute"/> <parameter key="2" value="Description.true.polynominal.attribute"/> <parameter key="3" value="Euro .true.real.attribute"/> <parameter key="4" value="Quantity.true.integer.attribute"/> <parameter key="5" value="EAN.true.real.attribute"/> </list> </operator> <operator activated="true" class="aggregate" compatibility="6.2.000" expanded="true" height="76" name="Aggregate" width="90" x="380" y="30"> <list key="aggregation_attributes"> <parameter key="Euro" value="average"/> <parameter key="Euro" value="maximum"/> <parameter key="Euro" value="standard_deviation"/> </list> <parameter key="group_by_attributes" value="Category"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
