Hello Everyone!
I have a small data set (101 datas) which i am using to train a naive bayes classifier with three class. Correct, Wrong, Uncertain. The results im getting shows low class recall with the "Wrong" class even though it has the largest number of data involved (55/101).
The process i am using.
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<parameter key="logverbosity" value="off"/>
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="5.3.013" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="C:\Users\user1.user\Desktop\Latest Training.xlsx"/>
<parameter key="imported_cell_range" value="A1:B112"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="Text.true.text.attribute"/>
<parameter key="1" value="Label.true.text.label"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="false"/>
<operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30">
<operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role" width="90" x="313" y="30">
<parameter key="attribute_name" value="Label"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="447" y="30">
<parameter key="keep_text" value="true"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="9999"/>
<list key="specify_weights">
<parameter key="Text" value="1.0"/>
</list>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="165"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="75">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="999"/>
<operator activated="true" class="text:stem_snowball" compatibility="5.3.002" expanded="true" height="60" name="Stem (Snowball)" width="90" x="246" y="165"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="581" y="30">
<parameter key="use_local_random_seed" value="true"/>
<operator activated="false" class="weka:W-NaiveBayes" compatibility="5.3.001" expanded="true" height="76" name="W-NaiveBayes" width="90" x="112" y="75"/>
<operator activated="true" class="naive_bayes" compatibility="5.3.013" expanded="true" height="76" name="Naive Bayes" width="90" x="112" y="165"/>
<operator activated="false" class="k_nn" compatibility="5.3.013" expanded="true" height="76" name="k-NN" width="90" x="112" y="255">
<parameter key="measure_types" value="NumericalMeasures"/>
<connect from_port="training" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="276" y="30">
<parameter key="main_criterion" value="accuracy"/>
<parameter key="classification_error" value="true"/>
<parameter key="kappa" value="true"/>
<list key="class_weights"/>
<operator activated="true" class="store" compatibility="5.3.013" expanded="true" height="60" name="Store" width="90" x="180" y="120">
<parameter key="repository_entry" value="../data/AsthmaDiabetesModel"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="model" to_op="Store" to_port="input"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="training" to_port="result 2"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
</process>
</process>
Is there a problem on how I am applying naive bayes or is it a problem regarding my data? I also tried it with only two class (true/false) but it shows the same result. Sometimes the "Correct" class will yield a low class recall. Although it did give a proper reading when applied using SVM (using 2 class).
Thanks in advance!
Regards, Yvan
