r EXTENSION ISSUES WITH JAVA
I'm installing rapidminer in a clean installation of Windows ultimate 64bits, I just installed <JDK 8u25 with NetBeans 8.0.2> and form R I'm usisng the 2.15.0 versión. At this point there's not problems.
I downloaded RM 6.2, and proceed to install the extensión <R extensión 5.30 >, then once RM start it displays the installation guide for the extensión and follow this, and my enviroment right now looks this way:
PATH C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\010 Editor;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\ManagementStudio\;C:\Program Files (x86)\Microsoft SQL Server\120\DTS\Binn\;
C:\Program Files\R\R-2.15.0\bin\x64;C:\Program Files (x86)\MySQL\MySQL Fabric 1.5.2 & MySQL Utilities 1.5.2 1.5\;C:\Program Files (x86)\MySQL\MySQL Fabric 1.5.2 & MySQL Utilities 1.5.2 1.5\Doctrine extensions for PHP\
R_HOME C:\Program Files\R\R-2.15.0
JAVA_HOME C:\Program Files\RapidMiner\RapidMiner Studio\jre ( I tried previously with the java dir, but it didn't work either)
So far, I followed all the instructions line by line, I gave the jri path corectly, but once I launch RM, It reports an error related to java:
"Rapidminer studio launcher
Java could not be launched. Probably there is not enough free memory available. PLease close all other applications and try again.
errorcede: 10"
The point is that my Workstation has more than 12 GB space free memory available, the only programs running at the time are the server services for MYSQL and MS SQL express (two servers with no database at he moment - I just did the clean installation yesterday)
The next message from RM, is:
"Enter safe mode"
The last startup of rapidminer studio was interrupted or did not complete correctly. DO you want to enter safe mode? All Extensions are disabled in safe mode.
Disable extensions or Start normally"
The first option, let me run RM, the second just run the start creen and count all the modleule but at the take the exit and do nothing.
I always knew it about the difficulties installing this extensión, but this messages are new to me, any solution cross by desisntall RM and strat again.
launcher.log
ene 02, 2015 11:00:07 AM com.rapidminer.launcher.JVMOptionBuilder log
INFORMACIÓN: Trying to read user setting for maximum amount of memory.
INFORMACIÓN: No user setting for maximum amount of memory found.
INFORMACIÓN: Using G1 garbace collection with 16 parallel and 15 concurrent GC threads.
INFORMACIÓN: Calculating JVM memory settings...
INFORMACIÓN: Total physical memory detected: 16309
INFORMACIÓN: Calculating maximum usable memory for RapidMiner...
INFORMACIÓN: Set maximum usable memory to 14678mb
ene 02, 2015 11:00:08 AM com.rapidminer.launcher.JVMOptionBuilder log
INFORMACIÓN: Using 8192mb of memory.
INFORMACIÓN: Launch settings are: ' -XX:ConcGCThreads=15 -XX:ParallelGCThreads=16 -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -XX:InitiatingHeapOccupancyPercent=0 -Xms384m -Xmx8192m -XX:MaxPermSize=128m -Djava.net.preferIPv4Stack=true'
Some help will be apreciate.
Windows ultimate 64 bits
Java + netbeans 64 bits.
16 GB ram
2 processors (quad core 3.3GHHZ)
Rapidminer studio 6.2 64 bits (downloaded today)
Best regards,
Enrique Zapata
