<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="web:get_webpage" compatibility="5.3.002" expanded="true" height="60" name="Get Page" width="90" x="112" y="30"> <parameter key="url" value="http://www.lydmaskinen.dk/index.php"/> <list key="query_parameters"/> <list key="request_properties"/> </operator> <operator activated="true" class="web:extract_html_text_content" compatibility="5.3.002" expanded="true" height="60" name="Extract Content" width="90" x="246" y="30"/> <operator activated="true" class="text:documents_to_data" compatibility="6.1.000" expanded="true" height="76" name="Documents to Data" width="90" x="380" y="30"> <parameter key="text_attribute" value="Data"/> </operator> <operator activated="true" class="text:generate_extract" compatibility="6.1.000" expanded="true" height="60" name="Generate Extract" width="90" x="514" y="30"> <parameter key="source_attribute" value="Data"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="registered users" value=" .*users online.*([0-9])\sregistered.*guests.* "/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <connect from_op="Get Page" from_port="output" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
