<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.2.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="5"/> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="series:integrate_series" compatibility="5.3.000" expanded="true" height="76" name="Integrate" width="90" x="246" y="30"> <parameter key="attribute_name" value="att1"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Integrate" to_port="example set input"/> <connect from_op="Integrate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
