"Neural net: hidden layer size"
I’m trying to determine better number of nodes at a layer (just a single layer for simplicity): 1,2,3..10 nodes?
If I try 1, 2 or 3 nodes I get following results:
Error Number of nodes
0.4090900341097636 1
0.41810851436813457 2
0.4172135316516921 3
Now, if I only try 2 or 3 nodes I get following results:
0.4252654926064915 2
0.4188150897563617 3
Why do error (validation performance) changes? Process is below:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="5.3.015" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
<parameter key="number_examples" value="1000"/>
<operator activated="true" class="loop_parameters" compatibility="5.3.015" expanded="true" height="76" name="Loop Parameters" width="90" x="313" y="30">
<list key="parameters">
<parameter key="Set Macro.value" value="1,2,3"/>
</list>
<operator activated="true" class="set_macro" compatibility="5.3.015" expanded="true" height="76" name="Set Macro" width="90" x="45" y="30">
<parameter key="macro" value="L1"/>
<parameter key="value" value="3"/>
<operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation" width="90" x="313" y="30">
<parameter key="number_of_validations" value="5"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<parameter key="use_local_random_seed" value="true"/>
<parameter key="local_random_seed" value="1"/>
<operator activated="true" class="neural_net" compatibility="5.3.015" expanded="true" height="76" name="Neural Net" width="90" x="179" y="30">
<list key="hidden_layers">
<parameter key="Layer1" value="%{L1}"/>
</list>
<connect from_port="training" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_regression" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="282" y="30">
<parameter key="root_mean_squared_error" value="false"/>
<parameter key="relative_error_lenient" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="log" compatibility="5.3.015" expanded="true" height="76" name="Log" width="90" x="581" y="30">
<list key="log">
<parameter key="Err" value="operator.Validation.value.performance"/>
<parameter key="Nodes" value="operator.Set Macro.value.macro_value"/>
</list>
<connect from_port="input 1" to_op="Set Macro" to_port="through 1"/>
<connect from_op="Set Macro" from_port="through 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="Generate Data" from_port="output" to_op="Loop Parameters" to_port="input 1"/>
</process>
</process>
