onetwo
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.1.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="multi classification"/> </operator> <operator activated="true" class="remember" compatibility="6.1.000" expanded="true" height="60" name="Remember" width="90" x="179" y="30"> <parameter key="name" value="DataSet"/> </operator> <operator activated="true" class="subprocess" compatibility="6.1.000" expanded="true" height="76" name="Create Empty" width="90" x="313" y="30"> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="6.1.000" expanded="true" height="94" name="Filter Examples (2)" width="90" x="45" y="30"> <parameter key="condition_class" value="all"/> <parameter key="invert_filter" value="true"/> <list key="filters_list"/> </operator> <operator activated="true" class="remember" compatibility="6.1.000" expanded="true" height="60" name="Remember (3)" width="90" x="179" y="30"> <parameter key="name" value="ResultingSample"/> </operator> <connect from_port="in 1" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Remember (3)" to_port="store"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="read_csv" compatibility="6.1.000" expanded="true" height="60" name="Read CSV" width="90" x="447" y="120"> <parameter key="csv_file" value="C:\Users\Martin\Rapidforum\List"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="loop_values" compatibility="6.1.000" expanded="true" height="76" name="Loop Values" width="90" x="581" y="120"> <parameter key="attribute" value="att1"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="6.1.000" expanded="true" height="60" name="Recall" width="90" x="313" y="120"> <parameter key="name" value="DataSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.1.000" expanded="true" height="94" name="Filter Examples" width="90" x="447" y="120"> <parameter key="parameter_string" value="label=%{loop_value}"/> <parameter key="condition_class" value="attribute_value_filter"/> <list key="filters_list"/> </operator> <operator activated="true" class="remember" compatibility="6.1.000" expanded="true" height="60" name="Remember (2)" width="90" x="581" y="120"> <parameter key="name" value="ResultingSample"/> </operator> <connect from_port="example set" to_port="out 1"/> <connect from_op="Recall" from_port="result" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="recall" compatibility="6.1.000" expanded="true" height="60" name="Recall (2)" width="90" x="715" y="120"> <parameter key="name" value="DataSet"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Remember" to_port="store"/> <connect from_op="Remember" from_port="stored" to_op="Create Empty" to_port="in 1"/> <connect from_op="Create Empty" from_port="out 1" to_port="result 1"/> <connect from_op="Read CSV" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Recall (2)" from_port="result" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.1.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="multi classification"/> </operator> <operator activated="true" class="remember" compatibility="6.1.000" expanded="true" height="60" name="Remember" width="90" x="179" y="30"> <parameter key="name" value="DataSet"/> </operator> <operator activated="true" class="read_csv" compatibility="6.1.000" expanded="true" height="60" name="Read CSV" width="90" x="447" y="120"> <parameter key="csv_file" value="C:\Users\Martin\Rapidforum\List"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="loop_values" compatibility="6.1.000" expanded="true" height="76" name="Loop Values" width="90" x="581" y="120"> <parameter key="attribute" value="att1"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="6.1.000" expanded="true" height="60" name="Recall" width="90" x="313" y="120"> <parameter key="name" value="DataSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="6.1.000" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop_value}"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="false" class="filter_examples" compatibility="6.1.000" expanded="true" height="94" name="Filter Examples" width="90" x="514" y="390"> <parameter key="parameter_string" value="label=%{loop_value}"/> <parameter key="condition_class" value="attribute_value_filter"/> <list key="filters_list"/> </operator> <operator activated="true" class="remember" compatibility="6.1.000" expanded="true" height="60" name="Remember (2)" width="90" x="581" y="120"> <parameter key="name" value="DataSet"/> </operator> <connect from_port="example set" to_port="out 1"/> <connect from_op="Recall" from_port="result" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="recall" compatibility="6.1.000" expanded="true" height="60" name="Recall (2)" width="90" x="715" y="120"> <parameter key="name" value="DataSet"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Remember" to_port="store"/> <connect from_op="Remember" from_port="stored" to_port="result 1"/> <connect from_op="Read CSV" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Recall (2)" from_port="result" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
