<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="sort" compatibility="6.1.000" expanded="true" height="76" name="Sort" width="90" x="179" y="30"> <parameter key="attribute_name" value="a1"/> </operator> <operator activated="true" class="generate_id" compatibility="6.1.000" expanded="true" height="76" name="Generate ID" width="90" x="313" y="30"/> <operator activated="true" class="set_role" compatibility="6.1.000" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="attribute_name" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="rename" compatibility="6.1.000" expanded="true" height="76" name="Rename" width="90" x="581" y="30"> <parameter key="old_name" value="id"/> <parameter key="new_name" value="Rank"/> <list key="rename_additional_attributes"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve Sonar" width="90" x="112" y="30"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="loop_values" compatibility="6.1.000" expanded="true" height="76" name="Loop Values" width="90" x="313" y="30"> <parameter key="attribute" value="class"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="6.1.000" expanded="true" height="94" name="Filter Examples" width="90" x="45" y="30"> <parameter key="parameter_string" value="class=%{loop_value}"/> <parameter key="parameter_expression" value="class==%{loop_value}"/> <parameter key="condition_class" value="attribute_value_filter"/> <list key="filters_list"/> </operator> <operator activated="true" class="sort" compatibility="6.1.000" expanded="true" height="76" name="Sort" width="90" x="179" y="30"> <parameter key="attribute_name" value="attribute_1"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="generate_id" compatibility="6.1.000" expanded="true" height="76" name="Generate ID" width="90" x="313" y="30"/> <operator activated="true" class="set_role" compatibility="6.1.000" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="attribute_name" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="rename" compatibility="6.1.000" expanded="true" height="76" name="Rename" width="90" x="581" y="30"> <parameter key="old_name" value="id"/> <parameter key="new_name" value="Rank"/> <list key="rename_additional_attributes"/> </operator> <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.1.000" expanded="true" height="76" name="Append" width="90" x="447" y="30"/> <connect from_op="Retrieve Sonar" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
