<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="sort" compatibility="6.1.000" expanded="true" height="76" name="Sort" width="90" x="246" y="120"> <parameter key="attribute_name" value="a1"/> </operator> <operator activated="true" class="generate_id" compatibility="6.1.000" expanded="true" height="76" name="Generate ID" width="90" x="380" y="120"/> <operator activated="true" class="filter_examples" compatibility="6.1.000" expanded="true" height="94" name="Filter Examples" width="90" x="581" y="120"> <list key="filters_list"> <parameter key="filters_entry_key" value="id.lt.4"/> </list> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
