Forward Selection not as expected
User: "donelron"
New Altair Community Member
Updated by Jocelyn
Dear all,
I am trying to select a subset of features from my DB using the Forward Selection. However, the Forward Selection does not behave as I expect it to do. I am attaching an example process for which I used the Iris data set in order to make it possible for everybody to reproduce what I am doing:
The process would be as follows:
<process version="6.0.008">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process">
    <parameter key="parallelize_main_process" value="false"/>
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="300">
        <parameter key="repository_entry" value="//Samples/data/Iris"/>
      <operator activated="true" class="optimize_selection_forward" compatibility="6.0.008" expanded="true" height="94" name="Forward Selection" width="90" x="313" y="300">
        <parameter key="maximal_number_of_attributes" value="4"/>
        <parameter key="speculative_rounds" value="10"/>
        <parameter key="stopping_behavior" value="without increase"/>
        <parameter key="use_relative_increase" value="true"/>
        <parameter key="alpha" value="0.05"/>
        <parameter key="parallelize_learning_process" value="false"/>
          <operator activated="true" class="log" compatibility="6.0.008" expanded="true" height="60" name="Log" width="90" x="380" y="390">
            <parameter key="filename" value="U:\temp\LoggingOfDemoProcessForwardselectionMultinomial.log"/>
            <list key="log">
              <parameter key="Performance" value="operator.Performance.value.performance"/>
              <parameter key="NumberOfAttributes" value="operator.Forward Selection.value.number of attributes"/>
              <parameter key="FeatureNames" value="operator.Forward Selection.value.feature_names"/>
              <parameter key="Accuracy" value="operator.Performance.value.accuracy"/>
              <parameter key="ValidationPerformance" value="operator.Validation.value.performance"/>
              <parameter key="ValidationPerformance1" value="operator.Validation.value.performance1"/>
              <parameter key="ValidationPerformance2" value="operator.Validation.value.performance2"/>
              <parameter key="ValidationPerformance3" value="operator.Validation.value.performance3"/>
            </list>
            <parameter key="sorting_type" value="none"/>
            <parameter key="sorting_k" value="100"/>
            <parameter key="persistent" value="false"/>
          <operator activated="true" class="x_validation" compatibility="6.0.008" expanded="true" height="112" name="Validation" width="90" x="380" y="120">
            <description>A cross-validation evaluating a linear regression model.</description>
            <parameter key="create_complete_model" value="false"/>
            <parameter key="average_performances_only" value="true"/>
            <parameter key="leave_one_out" value="false"/>
            <parameter key="number_of_validations" value="2"/>
            <parameter key="sampling_type" value="stratified sampling"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="parallelize_training" value="false"/>
            <parameter key="parallelize_testing" value="false"/>
              <operator activated="true" class="k_nn" compatibility="6.0.008" expanded="true" height="76" name="k-NN" width="90" x="45" y="30">
                <parameter key="k" value="5"/>
                <parameter key="weighted_vote" value="false"/>
                <parameter key="measure_types" value="MixedMeasures"/>
                <parameter key="mixed_measure" value="MixedEuclideanDistance"/>
                <parameter key="nominal_measure" value="NominalDistance"/>
                <parameter key="numerical_measure" value="EuclideanDistance"/>
                <parameter key="divergence" value="GeneralizedIDivergence"/>
                <parameter key="kernel_type" value="radial"/>
                <parameter key="kernel_gamma" value="1.0"/>
                <parameter key="kernel_sigma1" value="1.0"/>
                <parameter key="kernel_sigma2" value="0.0"/>
                <parameter key="kernel_sigma3" value="2.0"/>
                <parameter key="kernel_degree" value="3.0"/>
                <parameter key="kernel_shift" value="1.0"/>
                <parameter key="kernel_a" value="1.0"/>
                <parameter key="kernel_b" value="0.0"/>
              <connect from_port="training" to_op="k-NN" to_port="training set"/>
              <connect from_op="k-NN" from_port="model" to_port="model"/>
              <portSpacing port="source_training" spacing="0"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="6.0.008" expanded="true" height="76" name="Apply_Model" width="90" x="45" y="30">
                <parameter key="create_view" value="false"/>
              <operator activated="true" class="performance_classification" compatibility="6.0.008" expanded="true" height="76" name="Performance" width="90" x="179" y="30">
                <parameter key="main_criterion" value="first"/>
                <parameter key="accuracy" value="true"/>
                <parameter key="classification_error" value="false"/>
                <parameter key="kappa" value="false"/>
                <parameter key="weighted_mean_recall" value="false"/>
                <parameter key="weighted_mean_precision" value="false"/>
                <parameter key="spearman_rho" value="false"/>
                <parameter key="kendall_tau" value="false"/>
                <parameter key="absolute_error" value="false"/>
                <parameter key="relative_error" value="false"/>
                <parameter key="relative_error_lenient" value="false"/>
                <parameter key="relative_error_strict" value="false"/>
                <parameter key="normalized_absolute_error" value="false"/>
                <parameter key="root_mean_squared_error" value="false"/>
                <parameter key="root_relative_squared_error" value="false"/>
                <parameter key="squared_error" value="false"/>
                <parameter key="correlation" value="false"/>
                <parameter key="squared_correlation" value="false"/>
                <parameter key="cross-entropy" value="false"/>
                <parameter key="margin" value="false"/>
                <parameter key="soft_margin_loss" value="false"/>
                <parameter key="logistic_loss" value="false"/>
                <parameter key="skip_undefined_labels" value="true"/>
                <parameter key="use_example_weights" value="true"/>
                <list key="class_weights"/>
              <operator activated="true" class="free_memory" compatibility="6.0.008" expanded="true" height="76" name="Free Memory (3)" width="90" x="313" y="30"/>
              <connect from_port="model" to_op="Apply_Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply_Model" to_port="unlabelled data"/>
              <connect from_op="Apply_Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
              <connect from_op="Performance" from_port="performance" to_op="Free Memory (3)" to_port="through 1"/>
              <connect from_op="Free Memory (3)" from_port="through 1" to_port="averagable 1"/>
              <portSpacing port="sink_averagable 1" spacing="0"/>
              <portSpacing port="sink_averagable 2" spacing="0"/>
            </process>
          <connect from_port="example set" to_op="Validation" to_port="training"/>
          <connect from_op="Validation" from_port="averagable 1" to_port="performance"/>
          <portSpacing port="sink_performance" spacing="0"/>
        </process>
      <connect from_op="Retrieve Iris" from_port="output" to_op="Forward Selection" to_port="example set"/>
      <connect from_op="Forward Selection" from_port="attribute weights" to_port="result 1"/>
      <connect from_op="Forward Selection" from_port="performance" to_port="result 2"/>
    </process>
</process>
...and my result which I logged to "U:\temp\LoggingOfDemoProcessForwardselection.log" as defined in the process looks like:
# Generated by Log[com.rapidminer.datatable.SimpleDataTable]
# Performance NumberOfAttributes FeatureNames Accuracy ValidationPerformance ValidationPerformance1 ValidationPerformance2 ValidationPerformance3
0.96 1.0 a1 0.96 0.9533333333333334 0.9533333333333334 null null
0.6666666666666666 1.0 a2 0.6666666666666666 0.6399999999999999 0.6399999999999999 null null
0.5066666666666667 1.0 a3 0.5066666666666667 0.52 0.52 null null
0.92 1.0 a4 0.92 0.9333333333333333 0.9333333333333333 null null
0.96 2.0 a4, a1 0.96 0.9666666666666667 0.9666666666666667 null null
0.8933333333333333 2.0 a4, a2 0.8933333333333333 0.9066666666666667 0.9066666666666667 null null
0.96 2.0 a4, a3 0.96 0.9466666666666667 0.9466666666666667 null null
0.9333333333333333 3.0 a4, a3, a1 0.9333333333333333 0.9533333333333334 0.9533333333333334 null null
0.9866666666666667 3.0 a4, a3, a2 0.9866666666666667 0.9733333333333334 0.9733333333333334 null null
0.9733333333333334 4.0 a4, a3, a1, a2 0.9733333333333334 0.9666666666666667 0.9666666666666667 null null
I am trying to understand what is happening, so I included all kinds of performances in the output.
Now, there are some things that are not as expected. For example: Apparently, a1 is the best (single) feature. However, a4, is instead chosen as the first feature. Could someone maybe explain if / why this is output is correct?
Thanks in advance and best regards,
