neither of the links is working:http://splab.cz/en/download/software/immi-rapidminer-extenison
http://www.burgsys.com/image-analysis-software.php
Any other solution?
maybe the problem is with the IPv6 addresses.
Anyway, can contact me using uher at burgsys dot com? Also include information if it is for private usage or for bussiness.
Best wishes,
Vaclav
I'm able to access those webpages, have also filled up the forms with email address and other details for downloading the extension. The message shows that they'll contact me, but none yet with the download link.
Amrita
Hi
I don't know about the problem with IPv6 addresses, but if it's related to accessing the webpage, then, I am able to access them. I have even filled up the required forms for download, but, no download link yet.
I have also sent you a mail regarding this.
Thanks and regards
User @Vaclawho appears to be working with burgsys replied earlier in the thread ..here is what he said. You can reach out directly with the email address he provided
Done so!
Thanks
Hi all
I got the extension link from Burgsys via @Vaclav.
Problem solved
Thanks for your replies
