<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="execute_script" compatibility="6.1.000" expanded="true" height="76" name="Execute Script" width="90" x="179" y="30"> <parameter key="script" value="ExampleSet es = input[0]; Attribute att = es.getAttributes().get("a1"); double value = es.getExample(4).getValue(att); es.getExample(6).setValue(att, value); return input;"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Execute Script" to_port="input 1"/> <connect from_op="Execute Script" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
