<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <parameter key="random_seed" value="-1"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.0.008" expanded="true" height="94" name="Fixed Partitions" width="90" x="313" y="30"> <parameter key="parameter_string" value="85"/> <parameter key="parameter_expression" value="contains("Iris-setosa,Iris-versicolor",label)"/> <parameter key="condition_class" value="expression"/> <list key="filters_list"/> </operator> <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Retrieve Iris (2)" width="90" x="45" y="255"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="set_macros" compatibility="6.0.008" expanded="true" height="76" name="Parameters" width="90" x="179" y="255"> <list key="macros"> <parameter key="target" value="label"/> <parameter key="partitions" value="2"/> </list> </operator> <operator activated="true" class="subprocess" compatibility="6.0.008" expanded="true" height="76" name="Random Partitions" width="90" x="313" y="255"> <process expanded="true"> <operator activated="true" class="multiply" compatibility="6.0.008" expanded="true" height="94" name="Multiply" width="90" x="45" y="30"/> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{target}"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="remove_duplicates" compatibility="6.0.008" expanded="true" height="76" name="Remove Duplicates" width="90" x="179" y="300"> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="transpose" compatibility="6.0.008" expanded="true" height="76" name="Transpose" width="90" x="246" y="165"/> <operator activated="true" class="select_by_random" compatibility="6.0.008" expanded="true" height="76" name="Select by Random" width="90" x="313" y="300"> <parameter key="use_fixed_number_of_attributes" value="true"/> <parameter key="number_of_attributes" value="%{partitions}"/> </operator> <operator activated="true" class="transpose" compatibility="6.0.008" expanded="true" height="76" name="Transpose (2)" width="90" x="380" y="165"/> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="447" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="join" compatibility="6.0.008" expanded="true" height="76" name="Join" width="90" x="581" y="30"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="%{target}" value="%{target}"/> </list> </operator> <connect from_port="in 1" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Join" to_port="left"/> <connect from_op="Multiply" from_port="output 2" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Select by Random" to_port="example set input"/> <connect from_op="Select by Random" from_port="example set output" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Fixed Partitions" to_port="example set input"/> <connect from_op="Fixed Partitions" from_port="example set output" to_port="result 1"/> <connect from_op="Retrieve Iris (2)" from_port="output" to_op="Parameters" to_port="through 1"/> <connect from_op="Parameters" from_port="through 1" to_op="Random Partitions" to_port="in 1"/> <connect from_op="Random Partitions" from_port="out 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
