<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Load Text" width="90" x="112" y="30"> <parameter key="text" value="T-Mobile US Inc. and two regional carriers, General Communication Inc. in Alaska and CT Cube LP in Texas. The order is subject to review by President Barack Obama. Commodities Oil futures rose 67 cents to $93.98 a barrel as U.S. crude supplies dropped, while gold for August delivery climbed $8 to $1,405 an ounce. Europe European markets finished sharply lower today with shares in London leading the region. The FTSE 100 was down 2.12% while France's CAC 40 was off 1.87% and Germany's DAX fell lower by 1.20%. [1]: http://www.proactiveinvestors.com/companies/overview/2245/Salesforce.com [2]: http://www.proactiveinvestors.comcompanies/overview/2245/salesforcecom--2245.html [3]: http://www.proactiveinvestors.com/companies/overview/2397/Goldman+Sachs [4]: http://www.proactiveinvestors.comcompanies/overview/3787/general-motors-company--3787.html [5]: http://www.proactiveinvestors.com/companies/overview/1189/Dell [6]: http://www.proactiveinvestors.comcompanies/overview/1189/dell-1189.html [7]: http://www.proactiveinvestors.com/companies/overview/1189/Dell [8]: http://www.proactiveinvestors.com/companies/overview/2306/Apple [9]: http://www.proactiveinvestors.comcompanies/overview/2306/apple-2306.html [10]: http://www.proactiveinvestors.com/companies/overview/4450/Samsung+Electronics [11]: http://www.proactiveinvestors.com/companies/overview/2306/Apple [12]:"/> </operator> <operator activated="true" class="text:replace_tokens" compatibility="5.3.002" expanded="true" height="60" name="Replace Tokens" width="90" x="447" y="30"> <list key="replace_dictionary"> <parameter key="\[\d*\][^\[\]]*" value="!!REPLACED!! "/> </list> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Load Text (2)" width="90" x="112" y="120"> <parameter key="text" value="T-Mobile US Inc. and two regional carriers, General Communication Inc. in Alaska and CT Cube LP in Texas. The order is subject to review by President Barack Obama. Commodities Oil futures rose 67 cents to $93.98 a barrel as U.S. crude supplies dropped, while gold for August delivery climbed $8 to $1,405 an ounce. Europe European markets finished sharply lower today with shares in London leading the region. The FTSE 100 was down 2.12% while France's CAC 40 was off 1.87% and Germany's DAX fell lower by 1.20%. [1]: http://www.proactiveinvestors.com/companies/overview/2245/Salesforce.com [2]: http://www.proactiveinvestors.comcompanies/overview/2245/salesforcecom--2245.html [3]: http://www.proactiveinvestors.com/companies/overview/2397/Goldman+Sachs [4]: http://www.proactiveinvestors.comcompanies/overview/3787/general-motors-company--3787.html [5]: http://www.proactiveinvestors.com/companies/overview/1189/Dell [6]: http://www.proactiveinvestors.comcompanies/overview/1189/dell-1189.html [7]: http://www.proactiveinvestors.com/companies/overview/1189/Dell [8]: http://www.proactiveinvestors.com/companies/overview/2306/Apple [9]: http://www.proactiveinvestors.comcompanies/overview/2306/apple-2306.html [10]: http://www.proactiveinvestors.com/companies/overview/4450/Samsung+Electronics [11]: http://www.proactiveinvestors.com/companies/overview/2306/Apple [12]:"/> </operator> <operator activated="true" class="text:remove_document_parts" compatibility="5.3.002" expanded="true" height="60" name="Remove Document Parts" width="90" x="447" y="120"> <parameter key="deletion_regex" value="\[\d*\][^\[\]]*"/> </operator> <connect from_op="Load Text" from_port="output" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_port="result 1"/> <connect from_op="Load Text (2)" from_port="output" to_op="Remove Document Parts" to_port="document"/> <connect from_op="Remove Document Parts" from_port="document" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="test" value="C:\Users\chris_000\Desktop\Master Doks\Arbeitsstand\Dictionary\General Inquirer\Beispiele"/> </list> <parameter key="use_file_extension_as_type" value="false"/> <parameter key="create_word_vector" value="false"/> <parameter key="keep_text" value="true"/> <process expanded="true"> <connect from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" compatibility="6.0.008" expanded="true" height="76" name="Set Role" width="90" x="179" y="30"> <parameter key="attribute_name" value="text"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="multiply" compatibility="6.0.008" expanded="true" height="94" name="Multiply" width="90" x="313" y="30"/> <operator activated="true" class="loop_files" compatibility="6.0.008" expanded="true" height="76" name="Load & Delete URLs" width="90" x="514" y="75"> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="5.3.002" expanded="true" height="60" name="Read Document" width="90" x="112" y="30"/> <operator activated="true" class="text:remove_document_parts" compatibility="5.3.002" expanded="true" height="60" name="Delete URLs" width="90" x="313" y="30"> <parameter key="deletion_regex" value="\[\d*\][^\[\]]*"/> </operator> <connect from_port="file object" to_op="Read Document" to_port="file"/> <connect from_op="Read Document" from_port="output" to_op="Delete URLs" to_port="document"/> <connect from_op="Delete URLs" from_port="document" to_port="out 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="45" y="255"> <list key="text_directories"> <parameter key="positive" value="C:\Users\chris_000\Desktop\Master Doks\Arbeitsstand\Dictionary\General Inquirer\Positive"/> </list> <parameter key="vector_creation" value="Binary Term Occurrences"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="313" y="30"/> <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (2)" width="90" x="447" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Stem (2)" to_port="document"/> <connect from_op="Stem (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="255"> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="179" y="30"/> <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="447" y="30"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_aggregation" compatibility="6.0.008" expanded="true" height="76" name="Generate Aggregation" width="90" x="313" y="255"> <parameter key="attribute_name" value="positive"/> </operator> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="255"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="metadata_path|text|positive|label|metadata_date|metadata_file"/> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files (3)" width="90" x="45" y="345"> <list key="text_directories"> <parameter key="negative" value="C:\Users\chris_000\Desktop\Master Doks\Arbeitsstand\Dictionary\General Inquirer\Negative"/> </list> <parameter key="vector_creation" value="Binary Term Occurrences"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (3)" width="90" x="180" y="30"/> <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (3)" width="90" x="416" y="30"/> <connect from_port="document" to_op="Tokenize (3)" to_port="document"/> <connect from_op="Tokenize (3)" from_port="document" to_op="Stem (3)" to_port="document"/> <connect from_op="Stem (3)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="179" y="345"> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (4)" width="90" x="180" y="30"/> <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (4)" width="90" x="484" y="30"/> <connect from_port="document" to_op="Tokenize (4)" to_port="document"/> <connect from_op="Tokenize (4)" from_port="document" to_op="Stem (4)" to_port="document"/> <connect from_op="Stem (4)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_aggregation" compatibility="6.0.008" expanded="true" height="76" name="Generate Aggregation (2)" width="90" x="313" y="345"> <parameter key="attribute_name" value="negative"/> </operator> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="447" y="345"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="metadata_path|text|negative|label|metadata_date|metadata_file"/> </operator> <operator activated="true" class="join" compatibility="6.0.008" expanded="true" height="76" name="Join" width="90" x="581" y="300"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="metadata_path" value="metadata_path"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="6.0.008" expanded="true" height="76" name="Generate Attributes" width="90" x="715" y="300"> <list key="function_descriptions"> <parameter key="Sentiment" value="(positive-negative)/(positive+negative)"/> </list> </operator> <operator activated="true" class="write_excel" compatibility="6.0.008" expanded="true" height="76" name="Write Excel" width="90" x="715" y="435"> <parameter key="excel_file" value="C:\Users\chris_000\Desktop\Output.xls"/> <parameter key="file_format" value="xlsx"/> <parameter key="sheet_name" value="RapidMiner Test"/> </operator> <operator activated="true" class="text:filter_documents_by_content" compatibility="5.3.002" expanded="true" height="76" name="Filter Twitter" width="90" x="648" y="75"> <parameter key="string" value="via twitter"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.002" expanded="true" height="94" name="Process Documents" width="90" x="782" y="75"> <process expanded="true"> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Load & Delete URLs" from_port="out 1" to_op="Filter Twitter" to_port="documents 1"/> <connect from_op="Process Documents from Files (2)" from_port="word list" to_op="Process Documents from Data" to_port="word list"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Generate Aggregation" to_port="example set input"/> <connect from_op="Generate Aggregation" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Process Documents from Files (3)" from_port="word list" to_op="Process Documents from Data (2)" to_port="word list"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Generate Aggregation (2)" to_port="example set input"/> <connect from_op="Generate Aggregation (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Write Excel" to_port="input"/> <connect from_op="Filter Twitter" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
