<?xml version="1.0" encoding="utf-8"?><data> <contract_id>int</contract_id> <amt_financed>decimal</amt_financed> <term>int</term> <customer> <party_id>int</party_id> <name>string</name> <sex>string</sex> <occupation>string</occupation> <salary>decimal</salary> </customer> <supplier> <party_id>int</party_id> <name>string</name> <supplier_segment>string</supplier_segment> </supplier></data>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="210"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="loop_examples" compatibility="6.0.008" expanded="true" height="94" name="Loop Examples" width="90" x="246" y="210"> <process expanded="true"> <operator activated="true" class="loop_attributes" compatibility="6.0.008" expanded="true" height="94" name="Loop Attributes" width="90" x="246" y="120"> <process expanded="true"> <operator activated="true" class="text:extract_document" compatibility="5.3.002" expanded="true" height="76" name="Extract Document" width="90" x="246" y="165"> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="CLose Tag (2)" width="90" x="246" y="615"> <parameter key="text" value="</%{loop_attribute}> "/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="CLose Tag (3)" width="90" x="514" y="660"> <parameter key="text" value="</%{loop_attribute}> "/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Open Tag" width="90" x="246" y="75"> <parameter key="text" value=" <%{loop_attribute}>"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="CLose Tag" width="90" x="246" y="255"> <parameter key="text" value="</%{loop_attribute}> "/> </operator> <operator activated="true" class="text:combine_documents" compatibility="5.3.002" expanded="true" height="112" name="Combine Documents" width="90" x="447" y="165"/> <connect from_port="example set" to_op="Extract Document" to_port="example set"/> <connect from_op="Extract Document" from_port="document" to_op="Combine Documents" to_port="documents 2"/> <connect from_op="Open Tag" from_port="output" to_op="Combine Documents" to_port="documents 1"/> <connect from_op="CLose Tag" from_port="output" to_op="Combine Documents" to_port="documents 3"/> <connect from_op="Combine Documents" from_port="document" to_port="result 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Close XML" width="90" x="246" y="255"> <parameter key="text" value="</data>"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Begin XML" width="90" x="246" y="30"> <parameter key="text" value="<?xml version="1.0" encoding="utf-8"?> <data> "/> </operator> <operator activated="true" class="text:combine_documents" compatibility="5.3.002" expanded="true" height="112" name="Combine Documents (2)" width="90" x="447" y="120"/> <operator activated="true" class="text:write_document" compatibility="5.3.002" expanded="true" height="76" name="Write Document" width="90" x="581" y="120"> <parameter key="file" value="C:\Users\hhomburg\Documents\out_%{example}.xml"/> </operator> <connect from_port="example set" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="result 1" to_op="Combine Documents (2)" to_port="documents 2"/> <connect from_op="Close XML" from_port="output" to_op="Combine Documents (2)" to_port="documents 3"/> <connect from_op="Begin XML" from_port="output" to_op="Combine Documents (2)" to_port="documents 1"/> <connect from_op="Combine Documents (2)" from_port="document" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
