i want to normalze my table (range transforamtion), but there are different zero values. Before transformation there are only zeros in the first row, after tranformation i realized that there are values like:
0.030 ; 0.028 ; 0.031
Of course there are some negative values in the source table and so the zero isnt the zero anymore. I want that for each row and each column the value transformation is bijective.
Im able to write some groovy script to fix this, but i hope there is another way to do this.
Thanks for help!
edit:
Maybe this example demonstrate my problem.
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="5.3.013" expanded="true" height="60" name="Generate Data" width="90" x="112" y="75"/>
<operator activated="true" class="execute_script" compatibility="5.3.013" expanded="true" height="76" name="Execute Script" width="90" x="246" y="75">
<parameter key="script" value="ExampleSet exampleSet = input[0]; Attributes attributes = exampleSet.getAttributes(); int count = 0; Attribute att1 = attributes.get("att1"); Attribute att2 = attributes.get("att2"); Attribute att3 = attributes.get("att3"); Attribute att4 = attributes.get("att4"); Attribute att5 = attributes.get("att5"); exampleSet.getExample(0).setValue(att1, count); exampleSet.getExample(0).setValue(att2, count); exampleSet.getExample(0).setValue(att3, count); exampleSet.getExample(0).setValue(att4, count); exampleSet.getExample(0).setValue(att5, count); return exampleSet;"/>
<operator activated="true" breakpoints="before" class="normalize" compatibility="5.3.013" expanded="true" height="94" name="Normalize" width="90" x="380" y="75">
<parameter key="method" value="range transformation"/>
<connect from_op="Generate Data" from_port="output" to_op="Execute Script" to_port="input 1"/>
<connect from_op="Execute Script" from_port="output 1" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_port="result 1"/>
</process>
</process>
