<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.0.008" expanded="true" height="60" name="Generate Data" width="90" x="112" y="75"> <parameter key="number_examples" value="10"/> <parameter key="attributes_lower_bound" value="-1.0"/> <parameter key="attributes_upper_bound" value="5.0"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.0.008" expanded="true" height="76" name="Generate Attributes" width="90" x="112" y="165"> <list key="function_descriptions"> <parameter key="att1" value="round(att1)"/> <parameter key="constant" value="1"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="255"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="constant|att1"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="sort" compatibility="6.0.008" expanded="true" height="76" name="Sort" width="90" x="313" y="75"> <parameter key="attribute_name" value="att1"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="aggregate" compatibility="6.0.008" expanded="true" height="76" name="Aggregate" width="90" x="313" y="165"> <list key="aggregation_attributes"> <parameter key="att1" value="median"/> </list> <parameter key="group_by_attributes" value="constant"/> </operator> <operator activated="true" class="sort" compatibility="6.0.008" expanded="true" height="76" name="Sort (2)" width="90" x="313" y="255"> <parameter key="attribute_name" value="att1"/> </operator> <operator activated="true" class="aggregate" compatibility="6.0.008" expanded="true" height="76" name="Aggregate (2)" width="90" x="313" y="345"> <list key="aggregation_attributes"> <parameter key="att1" value="median"/> </list> <parameter key="group_by_attributes" value="constant"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <connect from_op="Aggregate" from_port="original" to_op="Sort (2)" to_port="example set input"/> <connect from_op="Sort (2)" from_port="example set output" to_op="Aggregate (2)" to_port="example set input"/> <connect from_op="Aggregate (2)" from_port="example set output" to_port="result 2"/> <connect from_op="Aggregate (2)" from_port="original" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
