<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document" width="90" x="112" y="165"> <parameter key="text" value="apple banana lemon peach strawberry raspberry apple cherry melon"/> <parameter key="add label" value="true"/> <parameter key="label_value" value="doc1"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document (2)" width="90" x="112" y="255"> <parameter key="text" value=" banana lemon peach strawberry raspberry cherry melon"/> <parameter key="add label" value="true"/> <parameter key="label_value" value="doc2"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document (3)" width="90" x="112" y="390"> <parameter key="text" value="apple banana lemon peach strawberry raspberry apple cherry melon apple banana lemon peach strawberry raspberry apple cherry melon"/> <parameter key="add label" value="true"/> <parameter key="label_value" value="doc3"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.002" expanded="true" height="130" name="Process Documents" width="90" x="380" y="165"> <parameter key="vector_creation" value="Term Occurrences"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents" to_port="documents 2"/> <connect from_op="Create Document (3)" from_port="output" to_op="Process Documents" to_port="documents 3"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
