Altair RISE
Nominate Yourself Now!
Altair RapidMiner
Linux command line using csv file [sentiment analysis]
snake0
Hello all,
I am trying to run a process built with the Sentiment Analysis wizard via command line and cannot find the way to do it.
The wizard built a bunch of subdirectories but I managed to organize them into the following:
repositories/Analyze
Analyze.properties
process.properties
process.rmp
input.ioo, input,md, input.properties
I also ran this with the GUI and it works, so I know these are the only files required. What I actually want to do is use the process with a new csv file each time in a script, so I presume I get rid of the three input.* files.
I found the command line tool and for a start tried to just run it with the 3 input files that were already compiled:
scripts/rapidminer-batch.sh -f /var/www/rapidminer-studio/repositories/Analyze/process.rmp
However this process fails.
process.rmp contains the following at the top of the file:
<input>
<location>input</location>
</input>
<output/>
<macros>
<macro>
<key>label</key>
<value>Sentiment</value>
</macro>
<macro>
<key>label_positive_class</key>
<value>positive</value>
</macro>
<macro>
<key>label_negative_class</key>
<value>negative</value>
</macro>
</macros>
So I should probably be getting rid of the 3 input files and the <input><location>input</location></input> part in process.rmp. The macros denote the format of my csv file originally used, so presumably as long as I use another csv file with the same format it should work.
Only problem is, I have no idea how to do this via the command line. Could anyone help?
Comments
There are no comments yet
My Discussions
