<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="5.3.015" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75"> <parameter key="csv_file" value="C:\Documents and Settings\menghii1\Desktop\text.txt"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="line.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="text:generate_extract" compatibility="5.3.002" expanded="true" height="60" name="Generate Extract" width="90" x="179" y="75"> <parameter key="source_attribute" value="line"/> <parameter key="query_type" value="Indexed"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"> <parameter key="RECORD_N" value="0.2"/> <parameter key="ID_NumNR_ACCOUNT" value="15.21"/> <parameter key="PROG" value="49.1"/> <parameter key="NOME" value="63.50"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="line"/> <parameter key="invert_selection" value="true"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
