<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Retrieve Golf" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="naive_bayes" compatibility="6.0.008" expanded="true" height="76" name="Naive Bayes" width="90" x="246" y="75"/> <operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="380" y="75"> <parameter key="report_name" value="My Distribution Table"/> <parameter key="pdf_output_file" value="C:\Users\hhomburg\Documents\test.pdf"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="514" y="75"> <parameter key="report_name" value="My Distribution Table"/> <parameter key="report_item_header" value="Distributions"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Distribution Model"/> <parameter key="renderer_name" value="Distribution Table"/> <list key="parameters"> <parameter key="min_row" value="1"/> <parameter key="max_row" value="2147483647"/> <parameter key="min_column" value="1"/> <parameter key="max_column" value="2147483647"/> <parameter key="sort_column" value="2147483647"/> <parameter key="sort_decreasing" value="false"/> </list> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
