<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Root"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Sonar" width="90" x="380" y="30"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="split_validation" compatibility="6.0.008" expanded="true" height="112" name="Validation" width="90" x="514" y="30"> <process expanded="true"> <operator activated="true" class="stacking" compatibility="6.0.008" expanded="true" height="60" name="Stacking" width="90" x="112" y="30"> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="attribute_29|attribute_28|attribute_27|attribute_26|attribute_25|attribute_24|attribute_23|attribute_22|attribute_21|attribute_20|attribute_2|attribute_19|attribute_18|attribute_17|attribute_16|attribute_15|attribute_14|attribute_13|attribute_12|attribute_11|attribute_10|attribute_1|class"/> </operator> <operator activated="true" class="decision_tree" compatibility="6.0.008" expanded="true" height="76" name="Decision Tree" width="90" x="246" y="30"/> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="112" y="210"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="attribute_49|attribute_48|attribute_47|attribute_46|attribute_45|attribute_44|attribute_43|attribute_42|attribute_41|attribute_40|attribute_4|attribute_39|attribute_38|attribute_37|attribute_36|attribute_35|attribute_34|attribute_33|attribute_32|attribute_31|attribute_30|attribute_3|class"/> </operator> <operator activated="true" class="k_nn" compatibility="6.0.008" expanded="true" height="76" name="K-NN" width="90" x="246" y="210"> <parameter key="k" value="5"/> </operator> <operator activated="true" class="select_attributes" compatibility="6.0.008" expanded="true" height="76" name="Select Attributes (3)" width="90" x="112" y="390"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="class|attribute_9|attribute_8|attribute_7|attribute_60|attribute_6|attribute_59|attribute_58|attribute_57|attribute_56|attribute_55|attribute_54|attribute_53|attribute_52|attribute_51|attribute_50|attribute_5"/> </operator> <operator activated="true" class="linear_regression" compatibility="6.0.008" expanded="true" height="94" name="Linear Regression" width="90" x="246" y="390"/> <connect from_port="training set 1" to_op="Select Attributes" to_port="example set input"/> <connect from_port="training set 2" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_port="training set 3" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="base model 1"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="K-NN" to_port="training set"/> <connect from_op="K-NN" from_port="model" to_port="base model 2"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="model" to_port="base model 3"/> <portSpacing port="source_training set 1" spacing="0"/> <portSpacing port="source_training set 2" spacing="0"/> <portSpacing port="source_training set 3" spacing="0"/> <portSpacing port="source_training set 4" spacing="0"/> <portSpacing port="sink_base model 1" spacing="0"/> <portSpacing port="sink_base model 2" spacing="0"/> <portSpacing port="sink_base model 3" spacing="0"/> <portSpacing port="sink_base model 4" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="6.0.008" expanded="true" height="76" name="Naive Bayes" width="90" x="123" y="30"/> <connect from_port="stacking examples" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="stacking model"/> <portSpacing port="source_stacking examples" spacing="0"/> <portSpacing port="sink_stacking model" spacing="0"/> </process> </operator> <connect from_port="training" to_op="Stacking" to_port="training set"/> <connect from_op="Stacking" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="6.0.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="6.0.008" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Sonar" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="18"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
