Marco Boeck wrote:Hi,can you please post the process xml of your setup? (Click von "View" -> "Show View" -> "XML" in the top menu bar and copy&paste the xml here)Regards,Marco
Marco Boeck wrote:Hi,you can try and add a breakpoint after the "Select Attributes" operator. Then you see the actual data coming into the "Set Role" operator. Make sure that the selected attribute does actually exist in your data. Normally it should simply tell you that the attribute does not exist, but it might be a bug that existed in RM Studio 5 and was fixed in RM Studio 6.Regards,Marco
