<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.009" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="loop_attributes" compatibility="6.0.009" expanded="true" height="76" name="Loop Attributes" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="6.0.009" expanded="true" height="76" name="Generate Macro" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="name" value="concat("%{loop_attribute}", "_0")"/> </list> </operator> <operator activated="true" class="rename" compatibility="6.0.009" expanded="true" height="76" name="Rename" width="90" x="246" y="30"> <parameter key="old_name" value="%{loop_attribute}"/> <parameter key="new_name" value="%{name}"/> <list key="rename_additional_attributes"/> </operator> <connect from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
