Read files from FTP
d_hofmann84
Hi together,
I would like to read CSV files from a FTP-Server on a daily base. (lets assume, that a script drops every day a new file there). Is there any possebility to do so? I know that I can set Cron Jobs on RapidMiner Server, but I don't know an operator which is capable of reading files from FTP. Or maybe there is an workaround...
Cheers and many thanks,
Daniel
JEdward
A little bit of Groovy script (The Script Operator) does the trick.
I'll see if I can knock you up a simple process example, but it's pretty much a straight copy of the ones you'll find on groovy forums.
d_hofmann84
Hi JEdward,
that would be awesome if you could drop some script snipped. I will also have a look at the forum you mentioned.
many thanks!!
d_hofmann84
Hi together,
i just solved the problem by using the normal Read CSV Operator. Just use the normal syntax e.g.: "
ftp://user:password@test.server.de/html/test.csv
" and alter the filename with makros.
Cheers
Daniel
