Does anyone know which is better for memory management, I have a loop which generates a collection inside another loop. (So the final output is several collections).
I need to append these collections together into a final example set and I wonder if anyone has any opinions on which is better for memory management, adding an append operator once (just before the final output) or twice (just outside the nested loop and the just before the final output).
Below is a small example showing what I mean.
In my final model I've gone with the first option as in my mind it seems better to join lots of small bits together at the end than small bits, then medium sized bits. However, I'm happy to be corrected.
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="5.3.015" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="multiply" compatibility="5.3.015" expanded="true" height="94" name="Multiply" width="90" x="45" y="120"/>
<operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="Option 1" width="90" x="179" y="30">
<operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes (3)" width="90" x="45" y="120">
<parameter key="Option" value=""Option 1""/>
</list>
<operator activated="true" class="loop" compatibility="5.3.015" expanded="true" height="76" name="Loop" width="90" x="112" y="30">
<parameter key="set_iteration_macro" value="true"/>
<parameter key="iterations" value="20"/>
<operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes" width="90" x="112" y="30">
<parameter key="1stLoopID" value="%{iteration}"/>
</list>
<operator activated="true" class="loop" compatibility="5.3.015" expanded="true" height="76" name="NestedLoop" width="90" x="246" y="30">
<parameter key="macro_name" value="nestediteration"/>
<parameter key="iterations" value="10"/>
<operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="112" y="75">
<parameter key="NestedLoopID" value="%{nestediteration}"/>
</list>
<connect from_port="input 1" to_op="Generate Attributes (2)" to_port="example set input"/>
<connect from_op="Generate Attributes (2)" from_port="example set output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="NestedLoop" to_port="input 1"/>
<connect from_op="NestedLoop" from_port="output 1" to_port="output 1"/>
</process>
<operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="76" name="Option 1 Append" width="90" x="246" y="30"/>
<connect from_port="in 1" to_op="Generate Attributes (3)" to_port="example set input"/>
<connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Loop" to_port="input 1"/>
<connect from_op="Loop" from_port="output 1" to_op="Option 1 Append" to_port="example set 1"/>
<connect from_op="Option 1 Append" from_port="merged set" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="Option 2" width="90" x="179" y="120">
<operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes (4)" width="90" x="45" y="30">
</list>
<operator activated="true" class="loop" compatibility="5.3.015" expanded="true" height="76" name="Loop (2)" width="90" x="180" y="30">
<operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes (5)" width="90" x="45" y="30">
</list>
<operator activated="true" class="loop" compatibility="5.3.015" expanded="true" height="76" name="NestedLoop (2)" width="90" x="248" y="30">
<operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" name="Generate Attributes (6)">
</list>
<connect from_port="input 1" to_op="Generate Attributes (6)" to_port="example set input"/>
<connect from_op="Generate Attributes (6)" from_port="example set output" to_port="output 1"/>
</process>
<operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="76" name="Append (3)" width="90" x="246" y="120"/>
<connect from_port="input 1" to_op="Generate Attributes (5)" to_port="example set input"/>
<connect from_op="Generate Attributes (5)" from_port="example set output" to_op="NestedLoop (2)" to_port="input 1"/>
<connect from_op="NestedLoop (2)" from_port="output 1" to_op="Append (3)" to_port="example set 1"/>
<connect from_op="Append (3)" from_port="merged set" to_port="output 1"/>
</process>
<operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="76" name="Option 2 Append" width="90" x="306" y="30"/>
<connect from_port="in 1" to_op="Generate Attributes (4)" to_port="example set input"/>
<connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Loop (2)" to_port="input 1"/>
<connect from_op="Loop (2)" from_port="output 1" to_op="Option 2 Append" to_port="example set 1"/>
<connect from_op="Option 2 Append" from_port="merged set" to_port="out 1"/>
</process>
<connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Option 1" to_port="in 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="Option 2" to_port="in 1"/>
<connect from_op="Option 1" from_port="out 1" to_port="result 1"/>
<connect from_op="Option 2" from_port="out 1" to_port="result 2"/>
</process>
</process>
