When using “read csv” operator to import csv file, I have the following problem.
If a given cell has a “
,”, the word following it will not be read. I think this is because the “,” is used as the column operator. But for this case, “,” is just an character appeared in a string . How can I let rapidminer skip this “,” in the string.
The following is the test csv file, which just include one row with two columns. The main content is just a text string. in the gnerated wordlist, we can find that the word "
what" was not read due to the "
," appearing before it.
ID Text Field 1 wow <Content>, what charm!
The following is the process
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="5.3.008" expanded="true" height="60" name="Read CSV" width="90" x="45" y="165">
<parameter key="csv_file" value="C:\Users\LocalRepository\Source_Data\test3.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="GBK"/>
<parameter key="0" value="ID.true.integer.id"/>
<parameter key="1" value="Text Field.true.text.attribute"/>
</list>
<operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="120">
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (3)" width="90" x="179" y="120"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (3)" width="90" x="313" y="120"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (3)" width="90" x="447" y="120">
<parameter key="min_chars" value="1"/>
<parameter key="max_chars" value="200"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="255"/>
<connect from_port="document" to_op="Tokenize (3)" to_port="document"/>
<connect from_op="Tokenize (3)" from_port="document" to_op="Transform Cases (3)" to_port="document"/>
<connect from_op="Transform Cases (3)" from_port="document" to_op="Filter Tokens (3)" to_port="document"/>
<connect from_op="Filter Tokens (3)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="word list" to_port="result 1"/>
</process>
</process>
