Hello people,
I'm currently working with RapidMiner 6 and at the end of a process I have to pipe out the Data Set to a Java Program.
In the documentation says that a process like : "Write CSV (fil) -> (in) Execute Program" will send the data set through the standard output to the program I'm executing, but the the process keeps failing and returning an error.
I'm using the following code in Java
public class WakaMain {
public static void main(String[] args) throws IOException {
ArrayList<String> input = new ArrayList<String>();
BufferedReader br = new BufferedReader(new InputStreamReader(System.in));
String inLine = br.readLine();
int i = 0;
while(i < 10){
input.add(inLine);
i++;
br.close();
writeStream(input);
System.out.println("Done: "+input.size()+" Inputs");
public static void writeStream(ArrayList<String> in) throws IOException{
FileWriter fw = new FileWriter("StreamWriteOutput.csv");
PrintWriter pw = new PrintWriter(fw);
for(int i = 0; i<in.size();i++){
pw.println(in.get(i));
pw.close();
And every time I run the process I get the following error:
What am I doing wrong here? D=
